Running GARCH model repeatedly in different pages
Posted: Fri Mar 01, 2013 9:24 am
by jdollery
In the past I always used the built-in functions in Eviews. I never program in Eviews before. With my current project I need to click the same function icon over 10000 times in order to get all results. I would very appreciate if someone could help to solve the following question.
My workfile contains 12 pages. On each page I need to run GARCH/TARCH with a mean equation for example, y= a +bx1+cx2+dx3+ex4. Manually I know how to do it by clicking "Quick -- estimation equation -- etc", I will get a result in the table format. Then I can freeze and copy this table into an excel sheet. However, I need to repeat this procedure at least 10000 times. If possible, could anyone provide some Eviews codes? So I can run GARCH/TARCH model in my workfile with 12 pages in one go.
Many thanks for your reply.
Jian
Re: Running GARCH model repeatedly in different pages
Posted: Fri Mar 01, 2013 9:44 am
You're best off reading some of the introduction to programming references, including the Programming chapter of the Command and Programming reference, and the guide in this very forum.
Posted: Fri Mar 01, 2013 10:26 am
by jdollery
Hi Gareth
Thanks for your reply and suggestions. Will read some program references.
Kind regards,
Jian
Posted: Thu Apr 04, 2013 3:39 am
by nerammaren
Hey!
I'm trying to run ARCH/GARCH/EGARCH in a loop writing a code and Eviews doesnt accept equationeq_!i = .... as a command. It doesnt regard it as an equation. Does anyone know what it would be???
