State space results differ
Posted: Thu Feb 28, 2013 11:05 am
by AmateurEviewsUser
Hey all,
I have been trying to estimate a state space model using Eviews 7. After figuring out how to provide initial values for state variables and parameters, I managed to converge the model and the results look fine.
However, problem arises when I try to plot the smoothed estimates of the state variable. When I do view -> state views -> Graphs state series- > smoothed state estimates and compare it with the series I get using proc -> make state series -> smoothed state estimates, I get totally different results.
Shouldn't I be getting the same result using both the options? I cant figure out where I am going wrong.
Would appreciate some help
Re: State space results differ
Posted: Thu Feb 28, 2013 11:10 am
Could you post your workfile?
Posted: Thu Feb 28, 2013 2:46 pm
And what's the date on your EViews 7 (Help/About EViews).
Posted: Fri Mar 01, 2013 12:23 am
Hey Glenn,
Eviews v7.1 has a build date of Feb 10, 2011 on it.
Hey Gareth,
Please find attached the graphs generated using the two options. Note: In the first graph the final value (SV1) is below 14 whereas in the second graph it goes close to 16. I don't understand the discrepancy. They look similar in their behavior but the magnitude differs.
Posted: Fri Mar 01, 2013 11:34 am
Before we go on, can you update to the latest version?
Posted: Wed Jun 21, 2017 1:46 pm
by akkerman
I am having the same problem. Using Eviews 9.
Posted: Thu Jun 22, 2017 9:45 am
I'll have to see a workfile with the estimated sspace object as I"m not seeing this behavior in my examples.
Posted: Thu Jun 22, 2017 12:30 pm
by akkerman
I have attached the workfile.
Posted: Fri Jun 30, 2017 2:45 pm
Thanks. I'll let you know when I figure out what's going on.
Posted: Wed Jul 05, 2017 5:14 pm
It looks as though our code for producing the state space graphs gets confused when you have an irregular dated workfile with gaps in the dated workfile structure. I'm working on a fix.
For now, you can produce the graphs by saving the results using the Procs and then constructing the graphs manually. I know that this is a bit of a pain and apologize for the inconvenience.
We'll get a fix out as soon as we can. Apologies again.
Posted: Thu Jul 06, 2017 4:41 am
by akkerman
Thank you Glenn.
Posted: Thu Jul 06, 2017 2:16 pm
A fix will appear in the next patch for both 9.5 and 10. Thanks for helping us locate the problem and sorry again for the inconvenience.
