Correlation between AR[p] processes
Posted: Wed Feb 20, 2013 9:05 am
Hello everyone,
I would like to compare five timeseries using their correlation coefficient with one another. The five series display significant autocorrelation. The AR[p] processes are unexpected in the context of the type of data (essentially similar to stock prices) and are attributable to the data generating process (self reported prices and performance-smoothing).
Three series are best described by univariate models of the type AR[1], two series by ARMA(1,1) models. The AR/MA processes can be assumed to be unnatural and result from the manipulation of the original data prior to reporting. Hence, the correlation between the timeseries may be over-/understated. The series should be manipulated so as to remove the AR/MA processes from the reported series.
My idea was to specify the best fitting ARMA models for the above series (in terms of Information criterion) and then use the residuals of those regressions to determine the factual correlation not attributable to autocorrelation and disturbance terms. Perhaps someone has come across a similar problem? Thanks in advance
