How do I create a dummy variable to correct for structural break within my data?
for example by looking at the resid graph shows a structural break in 1988 in my data
Data i have got given
c - constand
m
resid
r
y
kind regards
A
correct for structural break using dummy variable
Re: correct for structural break using dummy variable
series dummy = @year>1988
Thanks but when i do this, the coefficients change. aren't they meant to stay them same?
Kind regards
A.
Kind regards
A.
No, if the coefficients were going to stay the same what would you be correcting?Thanks but when i do this, the coefficients change. aren't they meant to stay them same?
Kind regards
A.
Oh thats true. thanks!
Also when use the dummy variable for lets say 1988
in my data for the dummy variable 1988 = 1 and all the rest of the dates are = to 0
but then if i in my data for the dummy variable 1988= 0 and the rest of the dates = 1
the coefficients are different from when 1988 = 1
which is correct?
Kind Regards
A.
which is correct?
Kind Regards
A.
Only the constant should have changed.
