program for 2 workfile pages
Posted: Thu Jan 31, 2013 6:25 am
by JamyOliver
Hey guys!
I need eviews for an event study analysis in my master thesis. First of all sorry for my englisch but I'm not a native as you'll see :lol:
My basic problem is that I have 2 pages in 1 workfile.
page1: has a range of 101 observations and has one table full of information for my programm (e.g. when the events occured)
page2: has a range of 881 observations and has all data of stocks+indices.
My problem is that I want to write a programm that gets its information out of my table of page 1, calculates log returns, expected returns in page 2 (according to the provided data of page 2). Additionally, I need all important information in page 1 to make a panel analysis. Important information are abnormal returns and some dummys that are related with it.
Is there any command that I can use to "switch" between the two pages in my program?! I found no solution for such a problem in the eviews guides.
Hopefully you understand my problem. Otherwise I have to explain it differently.
Thx for your help!
Re: program for 2 workfile pages
Posted: Thu Jan 31, 2013 7:29 am
pageselect
Posted: Fri Feb 01, 2013 3:17 am
by JamyOliver
EDIT: I'm using Eviews6
Yeah great! That is what I've searched!!! Thx for your help!
But I have still another, rather small problem. Is there any possibility that control variable is stored and can be used in the other page of the programm? I just need this because my two pages have a different range as I have described above. I tried it this way but it doesn't work:
for !t = 1 to 448
!q = testtable (!t, 1)
pageselect page2
smpl !q-10 !q+10
'etc.
Posted: Fri Feb 01, 2013 6:46 am
That will work.
Posted: Sat Feb 02, 2013 7:52 am
by JamyOliver
Thx for your support!
Now my whole program works!!! But I still have one problem to solve.
I want to copy some series from page2 to page 1 in my workfile (this makes my analysis easier). My first try was this command:
copy(smpl = 50 150) stocks_index\r_ab_1 result\
Basically, I can find my copy in page 1 but I still need to "cut" the sample. I wanted that the new copied series starts in Cell 1 with the first number of observation 50 of the other series that got copied. Generally, the numbers should be copied and presented beginning in cell 1 and ending in cell 101. Is this possible?
Posted: Wed Feb 06, 2013 2:23 am
by JamyOliver
Hmm ok last day I tried about 3-4hours to solve my problems with the User guides for Eviews 6.
I found some arguments (p.700 User Guide I) that solve a lot of problems but unfortunately not mine :x
Is there any argument or other possibility that solves my problem? Again: I want to copy only some parts of my series from one workfile to another. E.g. I have to copy sample 200 until 300 from Series 1 into a "new Series 1". But the new Series 1 should have only 101 observations (therefore, only the ones that I want to copy) from 1 to 101.
Posted: Wed Feb 06, 2013 9:40 am
Easiest way to do is it to make a series on each page that has the corresponding observation numbers, and use that to match-merge copy:
wfcreate(page=page1) u 300 series mydate = @trend+1 series x = nrnd pagecreate(page=page2) u 101 series mydate = @trend+200 copy page1\x page2\x @src mydate @dest mydate
Posted: Thu Dec 05, 2013 11:01 pm
by Alex_sad
i have the same problem.
i have two sheet in one workfile that each one has a different sample and i want to write a program to compare r squared of these two samples.
How can i mention sheet name in programming?
Thank you
Posted: Thu Dec 05, 2013 11:25 pm
Could you explain what you mean?
Posted: Sat Dec 07, 2013 8:11 am
by Alex_sad
i want to compare r squared of one model that run into two different sample therefore i have to compare two r squared for determining the difference is significant or not. so i used cramer z statistics.
Now i have a little problem:
Both of my samples are panel data with random effects therefore i can't sum them in one page
i have them in two different page. when i want write a program i can't switch between pages. How can i do this?
Posted: Sat Dec 07, 2013 2:00 pm
Pageselect
