VECM Help
Posted: Wed Jan 30, 2013 10:33 am
by faizan
Hi im constructing a vecm regression and need help interpreting the results. it would be much appreciated if you could helps me
I'm testing determinants of inflation, I've constructed unit root test along with co-integration test and am now struggling to understand my vecm results.
my dependent varible in cpi so in my vec model should i only be looking at the 1st error correction model labled d(cpi)on the horizontal axcis and using the coefficients of the varibles under that heading.
also using the standerd 2 lags and I don't understand why the coefficient sign changes for a variable with a lag, for example d(OIL(-1)) 0.0376 which i believe makes economic sense but d(OIL(-2)) = -0.006626 which from what i know goes against economic theory. and this trend happen for most my variables.
Also do these coefficients represent speed of adjustment in order to restore long run equilibrium.
Another question is what do the coefficients under the cointEq1,2,3 represent e.g unem(-1) 3.16834
hear is some of the model
Vector Error Correction Estimates
Date: 01/26/13 Time: 02:12
Sample (adjusted): 1970Q4 2011Q4
Included observations: 165 after adjustments
Standard errors in ( ) & t-statistics in [ ]
Cointegrating Eq: CointEq1 CointEq2 CointEq3
CPI(-1) 1.000000 0.000000 0.000000
INT2(-1) 0.000000 1.000000 0.000000
M2(-1) 0.000000 0.000000 1.000000
OIL(-1) -0.709087 0.012550 -9.81E+10
(0.13954) (0.02878) (1.3E+10)
[-5.08153] [ 0.43599] [-7.60147]
RGDP(-1) -9.08E-12 9.72E-13 -0.410964
(1.0E-12) (2.1E-13) (0.09211)
[-9.11989] [ 4.73313] [-4.46179]
UNEM(-1) 3.168342 -0.348349 3.94E+11
(1.18834) (0.24513) (1.1E+11)
2.66620] [-1.42110] [ 3.58698]
C 11.66774 -12.45975 2.93E+11
Error Correction: D(CPI) D(INT2) D(M2)
CointEq1 -0.016302 -0.021186 -1.67E+09
(0.00716) (0.01332) (5.4E+08)
[-2.27662] [-1.59089] [-3.09419]
CointEq2 0.109832 -0.070831 6.00E+08
(0.02082) (0.03871) (1.6E+09)
[ 5.27618] [-1.82968] [ 0.38287]
CointEq3 1.87E-13 1.18E-13 0.007580
(8.8E-14) (1.6E-13) (0.00663)
[ 2.12164] [ 0.71843] [ 1.14339]
D(CPI(-1)) -0.003501 0.174649 2.28E+10
(0.11985) (0.22289) (9.0E+09)
[-0.02921] [ 0.78357] [ 2.52581]
D(CPI(-2)) -0.392062 0.584066 -1.65E+09
(0.12175) (0.22641) (9.2E+09)
[-3.22027] [ 2.57965] [-0.18012]
D(INT2(-1)) 0.003713 0.157560 -1.21E+10
(0.04913) (0.09137) (3.7E+09)
[ 0.07557] [ 1.72445] [-3.28008]
D(INT2(-2)) -0.019054 -0.373610 -5.89E+09
(0.05211) (0.09690) (3.9E+09)
[-0.36567] [-3.85552] [-1.50139]
D(M2(-1)) 1.52E-12 -2.24E-12 0.216682
(1.2E-12) (2.3E-12) (0.09364)
[ 1.22494] [-0.96690] [ 2.31393]
D(M2(-2)) -5.07E-12 -2.04E-12 0.269365
(1.4E-12) (2.5E-12) (0.10275)
[-3.71738] [-0.80346] [ 2.62153]
D(OIL(-1)) 0.037611 -0.011235 -2.99E+09
(0.01018) (0.01893) (7.7E+08)
[ 3.69586] [-0.59365] [-3.90661]
D(OIL(-2)) -0.006626 -0.054824 1.90E+09
(0.01060) (0.01971) (8.0E+08)
[-0.62535] [-2.78221] [ 2.38376]
Re: VECM Help
Posted: Wed Jun 18, 2014 10:18 pm
by vas001
Pls see the videos of Prof Sayed Hossian of Bangladesh on YouTube. https://www.youtube.com/channel/UC9NRxX ... 9lnKxL7VsA
