Good evening, I need to import a serie in %change mode, not in default mode. Then, eviews can calculate an index by itself, is that possible?
Thx
Importing: not in default mode
Re: Importing: not in default mode
You'll need a value for the first year, but assuming you have that, just import the %change series, then calculate a new series off of it (here I'm seeding the X series at a value of 100, and assuming XCHANGE is the name of the %change series)
smpl @first @first
series x = 100
smpl @first+1 @last
x = x(-1)*(1+xchange)
gio.ortolani
what about the % change signaled in the link below? is that possible to import series in that mode?
https://www.dropbox.com/s/oqilo5ua1euemvq/pch.png
Same thing.
gio.ortolani
my range starts in 1980, but my Excel starts in 2012. i would like to maintain unaltered the sample from 1980 to 2011 that already exists in EViews and import only from 2012 to EViews. if I write @pch(series) in the code, it will be useless? i'm afraid that, in my case, the code you wrote won't help me.
Start the sample at the period you want to adjust then, rather than the first period in the workfile.
