Page 1 of 2
Rolling GARCH with forecasting
Posted: Thu Apr 16, 2009 3:10 am
by thomasft
Hi guys :)
I need to do a rolling estimation of a GARCH(1,1), outputting 1-day ahead forecast for the conditional variance.
I have 2869 observations a need a rolling window of 783. Therefor the first estimated GARCH should be based on observation 1 through 783, outputting a forecasted conditional variance for observation 784. Hereafter a new estimation based on 2 through 784, forecasting a conditional variance for observation 785 etc etc.
From other studies I have pieced together this code:
load var 'workfile with a return series called "return" containing 2869 observations
scalar noobs=2869
scalar nw=783
matrix(2869,1) results
for !i=nw to noobs
smpl !i-nw !i
equation garch_n
garch_n.ARCH(1,1) return
smpl !i !i
garch_n.forecast se var
scalar condvari_n = var
smpl @all
results(!i,1)=condvari_n
But apparently it doesnt work - can anyone give me a hint?
Secondly, I am looking into simulating a GARCH model 1000 times, calculating a return and finding the 5% quantile of the 1000 simulations. My code looks like this:
matrix(!sim,1) var_n
matrix(1,1) result
'SIMULATE
!m=1000
for !sim=1 to !m
equation garch_n
scalar omega_n = garch_n.@coefs(1)
scalar alpha_n = garch_n.@coefs(2)
scalar beta_n = garch_n.@coefs(3)
series z = nrnd
series sigmat2_n = omega_n + (alpha_n * z(-1)^2) + (beta_n * sigmat2_n(-1))
series r_n = z*@sqrt(sigmat2_n)
var_n(!sim)=r_n
result=@quantile(var_n, 0.05)
Is this code correct?
Re: Rolling GARCH with forecasting
Posted: Thu Apr 16, 2009 10:53 pm
by Gene
You need to set sample to the next period for the forecast.
As for the next set of code there is an issue with the line
the first observation is calculated as
sigmat2_n(t=1) = omega_n + (alpha_n * z(t=0)^2) + (beta_n * sigmat2_n(t=0))
See the problem? z(t=0) = NA, sigmat2_n(t=0)=na. So, sigmat2_n(t=1) = NA, and therefore sigmat2_n(t=2) = NA, etc.
I would do:
smpl @all
series z = nrnd
series sigmat2_n = z^2
smpl @first+1 @last
A second problem. You have
But var_n(!sim) is an 1x1 matrix (or scalar) and r_n is a n-length series, where n is the length of you workfile. They won't match.
There might be more problems.
Posted: Wed Jul 29, 2009 6:34 am
by Vaal1
I am quite new to using Eviews programs and I would like to implement the first code, rolling GARCH (1,1), for my present study. However, when I try to do so, it doesn't quite work. I keep geting an error message: series assigned to scalar in: ''SCALAR CONDVARI_N=VAR'' , and there are of course no results. I would be very grateful if you can tell me how to fix this problem please.
Posted: Wed Jul 29, 2009 9:43 am
by tchaithonov
Isn't var a series when you load it? What you've possibly done (I didn't really see that scalar condvari_n =var line anywhere in your code) is you are creating a scalar holder called condvari_n to hold var, which is, as the complaint says, a series. Maybe you want to change it to series condvari_n = var? I am just guessing since I don't know what you are trying to do.
Posted: Wed Jul 29, 2009 10:40 am
by Vaal1
I have modified the code according to your suggestion. At first it seems to work, but there are no results being generated. In this framework, I have a rolling window of 200 points and an overall sample size of 2703. Thus, at the end of the rolling estimation stage, I should end up with 2503 GARCH(1,1) estimates. However, after eviews finishes the computations, my results vector is only filled with zeroes. I have re-posted the code, and would be very grateful for any suggestions.
scalar noobs=2702
scalar nw=2000
matrix(2703,1) results
for !i=nw to noobs
smpl !i-nw !i
equation garch_n
smpl !i+1 !i+1
scalar condvari_n
smpl @all
Posted: Wed Jul 29, 2009 10:48 am
by startz
I think you've forgotten to put the result you want into condvari_n.
Posted: Wed Jul 29, 2009 10:55 am
by Vaal1
Thanks for the response. However, doesn't this line put the result into condvari_n? If not how do I go about doing so?
Posted: Wed Jul 29, 2009 11:08 am
by startz
No, that puts condvari_n into results(!i,1), not the other way around. So first you have to get whatever you're looking for into condvari_n.
Posted: Wed Jul 29, 2009 11:16 am
by Vaal1
Therein lies my problem: how do I get the computed GARCH(1,1) estimates into condvari_n? Any suggestions?
Posted: Wed Jul 29, 2009 10:07 pm
by tchaithonov
First of all, I am not sure why you have "return" after your <model_name>.arch, it shouldn't even work. Correct me if I am wrong, but isn't <model_name>.arch only pops up an ARCH result window for "Method: ML - ARCH (Marquardt) - Normal distribution"? Check the manual and see if there is a way to save the result separately.
So, the variable that contains the y_hat SERIES coming out from the forecast is "var". And in the latest code that you posted, you just created an empty scalar called condvari_n and putting it into an undeclared table RESULTS? Don't you need to do, at least, the following step?
table(noobs-nw,1) results ' this would be before the for loop
' (inside the loop)
results(!i,1) = .... ' whatever scalar values you are planning to drop into the table
Since you haven't assigned anything to condvari_n, obviously eviews would give you zeros as a result. Make sure you understand what values you want to get out of the ARCH, and find out from the manual what is the appropriate command to get the values you need.
Posted: Wed Jul 06, 2011 5:50 pm
by Abelima
hy!
please,
I want to know how to program the FIGARCH model in Eviews
thank you...
Abelima
Posted: Mon Aug 08, 2011 4:24 pm
by fariz888
Dear users,
I m recently doing my dissertation and faced with problem in estimation basic rolling GARCh (1,1) process. I have 2500 observation and need to forecast 1 day ahead volatility in rolling form. I will highly appreciate if advanced users provide me assistance in that issue.. I looked guideline but there was no information. In addition I have 6 day remaining to finish my dissertation. So I need your help immediately. Please share any knowledge that you have in that issue
Sincerely
Fariz
Thanks all
Posted: Wed Oct 05, 2011 6:53 am
by stasibab
Probably its a stupid question but I am forecasting the conditional volatility with GARCH(1,1) model using static forecast in eviews. When I click forecast my last observation in the out-sample-forecast is N.A for both the conditional volatilty and the s.e (see vol1, vol2 in the attached). Isn't the last observation in vol1&vol2 series ,the forecast of conditional volatility and the s.e for period (t=2295)
Any ideas why?
Thank you in advance!
Posted: Wed Oct 05, 2011 7:52 am
Without knowing what you did, it is hard to know what you did wrong.
Posted: Wed Oct 05, 2011 10:52 am
by stasibab
I am sorry I did not send you the eviews file with the equation.
Now you will be able to see it.
