Pooled Mean Group (PMG) Estimation
montepio
Postby montepio » Tue Nov 13, 2012 10:36 am
Dear,
Can you tell how to estimate a Pooled Mean Group (PMG)* model in Eviews? This is a panel data version of the error-correction model.
I was able to run a Panel Cointegration Test, so PMG estimator should be possible as well, but I couldn't find it.
Thank you in advance.
Regards,
José Maria Pimentel
Research Department
MONTEPIO
Lisbon, Portugal
*as in <Pesaran, H., Shin, Y., and Smith, R. (1999), “Pooled Mean Group Estimation of Dynamic
Heterogeneous Panels,” Journal of the American Statistical Association, 94: pp. 621-34.>
Re: Pooled Mean Group (PMG) Estimation
Postby EViews Glenn » Thu Nov 15, 2012 10:28 am
This is not an estimator that we currently support. For a moderate number of cross-sections, you could, in principle code it using the LOGL object since it's a a simple ML estimator. For large numbers of cross-sections, however, the projection onto subspace orthogonal to H_i in Equation 8 is required, and this would be considerably more difficult to address in the LOGL framework.
You would probably have more success with the back-substitution algorithm which uses only derivatives (Equation 9). This approach would only require iterative regression and is certainly doable in an EViews program. But again, we don't have anything built in yet.
I will make a note of your request and put it on the list of feature to consider for future versions.
carmomi
Postby carmomi » Tue Oct 08, 2013 12:45 am
The possibility of running pooled mean group estimation in dynamic heterogeneous panels is a feature that I also wish that could be available in a future Eviews update.
econworker
Postby econworker » Mon Aug 03, 2015 1:44 am
Dear Eviews Glenn
I am estimating a PMG model using Eviews 9, I have some variables that are multiplied to Dummy variables equal to zero for some cross sections, so variables are zero for some cross sections and numral values for other cross sections, however when I estimate the model with PMG I get the error of near singular Matrix, I tried the same data using stata, there was not any problem to estimate also I tried to estimate the model with panel OLS using eviews, i didnt receive any singular Matrix error, would you please tell me what could be the problem?
Postby EViews Gareth » Mon Aug 03, 2015 8:33 am
Could you provide the file?
econworker
Postby econworker » Wed Aug 05, 2015 4:51 am
I dont know why...but the file cant be attached, the messege get sent without file!
Postby EViews Gareth » Wed Aug 05, 2015 8:13 am
Try emailing it to support@eviews.com
econworker
Postby econworker » Mon Aug 24, 2015 9:42 am
Here is the file, the cor_z is dependant variable and the ones that start with mac_ and spec_ are explanatory variables, and y1, y2... are dummies
Stortroll
Postby Stortroll » Fri Dec 11, 2015 4:45 am
According to Eviews Help one should be able to estimate panel ARDL and PMG from within from the Equation Estimation menu reached fron New objets... or Quick estimation menu. I can't find that in latest version of Eviews 9. How come?
Postby EViews Glenn » Fri Dec 11, 2015 10:02 am
Just to double check, are you creating the new equation and then looking at the method dropdown?
naziblee
Postby naziblee » Sat Dec 19, 2015 6:25 am
Hi all, how many T and N is needed for PMG estimation to return consistent and unbiased estimate?
Santosh
Postby Santosh » Wed Mar 29, 2017 5:19 am
We can estimate PMG in EViews 9. How to estimate other estimators like Mean Group (MG) estimator and dynamic fixed effects (DFE)
estimator in EViews?
Help would be greatly appreciated.
Thank you.
