Beginner ARch Garch need help
diego45
Postby diego45 » Tue Nov 13, 2012 10:28 am
got the answer for my topic, Show next message below thanks
JimForest
Re: Beginner ARch Garch need help
Postby JimForest » Tue Nov 13, 2012 7:16 pm
Looks like you are just estimating the mean equation as arma(1,1) and the variance equation as Garch(1,1) by maximum likelihood with the mean equation assumed to follow a t-distribution.
Garch(1,1) is pretty standard and the distributional assumption doesn't sound outrageous.
Your forecast specification can either by static or dynamic. I'd look at that part of the user manual.
diego45
Postby diego45 » Wed Nov 14, 2012 3:09 am
Thanks for help
I have another question,
i get that graph :
What does it means ?
thanks
JimForest
Postby JimForest » Wed Nov 14, 2012 3:55 pm
Looks like a graph of the forecasted (static?) series with +-2 standard error forecast confidence intervals.
The static forecasts are a series of 1-step ahead forecasts.
diego45
Postby diego45 » Thu Nov 15, 2012 2:50 am
thanks for answer,
I don't know how to proceed. i have my garch equation : h(t) = c + 0,15 ut-1^2 + 0,88h(t-1)
so io should estimate the sigma(t+1).
But i can't estimate ht(t+2) (t+3) ... cause i don't have ut+1 ut+2 ...
Forecasting :
I have a sample range of 504 observations, so i resize the sample 1 - 300 i use garch modele to make an estimation of the conditional variance equation.
so i got this output :
Then i try to forecast the conditional variance. on the sample 300-504 like i have estimate on 1-300 i could call it "ex-post" forecasting
and i get this conditional variance.
So now i estimated with garch modele on the sample 300-504 and i get this conditional variance :
Is that the good procedure ?
I means my modele look like to be good no ?
if i have understood I cant forecast out of the sample ? or only for 505 ? cause after i don't have enought resid(t)^2 ?
So i can forecast the conditional variance t+1 ? and if i do it every day i could forecast forever :lol:
thanks you
