Non-integer power
martingale
Non-integer power
Postby martingale » Thu Nov 08, 2012 2:55 am
I get the error message that "you try to raise a negative number to a non-integer power".
Is there a way around this problem? I use Eviews 7.
This is caused in the process of estimating the parameter of risk aversion gamma in (C(t+1)/C(t))^gamma which appears in an euler equation of the consumption asset pricing model.
Re: Non-integer power
Postby EViews Gareth » Thu Nov 08, 2012 8:44 am
Without trying to be flippant, the only way around that problem is to not raise a negative number to a non-integer power.
martingale
Postby martingale » Thu Nov 08, 2012 11:03 am
One solution is using a loglinear transformation of the Hansen-Jagannathan bound but this would imply the assumption that the correlation of the stochastic discount factor and the volatility of consumption growth is equal to minus 1.
martingale
Postby martingale » Fri Jul 17, 2015 9:35 am
I realize this is a complicated question, see the discussion at http://math.stackexchange.com/questions ... ve-numbers
