Ctrl-C
jlbrillet
Ctrl-C
Postby jlbrillet » Tue Apr 14, 2009 6:57 am
On my computer, using Copy, then Paste repeatedly, each Ctrl-V takes a lot of time (several seconds) even for small strings (like three characters long).
Maybe it comes from my computer, but this happens only with Eviews.
Jean Louis Brillet.
Re: Ctrl-C
Postby EViews Gareth » Tue Apr 14, 2009 8:07 am
Where are you doing the pasting?
jlbrillet
Re: Ctrl-C
Postby jlbrillet » Wed Apr 15, 2009 3:38 am
Any time I edit a .prg file. But it seems to happen essentailly with large prgs. Like 20k+. And if I repeat the Ctrl-V quickly.
Jean Louis B.
Re: Ctrl-C
Postby EViews Gareth » Wed Apr 15, 2009 8:09 am
That is probably caused by the syntax colouring (it takes a while for it to catch up if you paste into a large program). If you turn off syntax colouring you should find it speeds it up.
Re: Ctrl-C
Postby EViews Jason » Thu Sep 10, 2009 3:20 pm
There was also an update patch posted some time ago which sped up pasting. If you havent already updated your copy, please do so.
