correlation between regression residuals
Posted: Sun Oct 28, 2012 4:32 am
I am applying a meta-analysis method to an unbalanced panel dataset.
I need to calculate the average correlation between regression residuals.
so far I am doing the equation per each year, I create the residual series, I export it to excel and then I ll calculate manually the correlation between different years.
Does it exist a direct command in Eviews to do it?
given that is an unbalanced panel data (i.e. the observation among years are not the same) does the correlation of residuals is biased on the number of observation?
thank you
thank you
