Reading in string from EViews
PMaier
Postby PMaier » Thu Oct 25, 2012 10:57 am
I have a bit of difficulties to import a string from Excel.
In the attached text file, I have build a string containing a number of spaces. The scenario is as follows: I already have a workfile open, and would like to read in this string and assign it to, say, variable "%list" in EViews. Then, I will loop through the different elements of the string.
I had some difficulties with the "read" command, as e.g.
read(t=txt) "h:\ListOfScenarios.txt" name $ test
only returns NA's.
Any advice or sample code would be highly appreciated,
Philipp
ListOfScenarios.txt
(428 Bytes) Downloaded 378 times
Re: Reading in string from EViews
Postby EViews Gareth » Thu Oct 25, 2012 11:24 am
text mytext mytext.append(file) "h:\ListOfScenarios.txt" mytext.svector mysvec %mylist = mysvec(1)
PMaier
Postby PMaier » Thu Oct 25, 2012 11:50 am
Whoaa!
Works. Many thanks! Philipp
