Residuals series used to calculate WLS Standard Errors
Posted: Fri Oct 19, 2012 2:29 pm
I am trying to figure out how Eviews calculate the weighted least squares standard errors, and I found out that, by using the residuals from the Actual,Fitted,Residuals Table, the sqrt of the diagonal of the resulting variance-covariance matrix is off by a constant compared to the reported standard errors in the equation window. I compare the results with the ones given by a weighted lm in R and if the regression command is as follows:
you could get 2 different residual series by the following:
1)
2)
The reason why I bring up R here is because, result 1) is the same as the residual series reported in the Actual,Fitted,Residuals table, while 2) is the one used to calculate standard error in the equation window. I want to know how I could get to the residual series calculated by option 2). Would anyone mind sharing some ideas? Thanks.
Tchaithonov
output <- lm(function=y~x1+x2+x3, weights=weight)
1)
> output$residuals
> summary(output)$residuals
Tchaithonov
