About Fixed/Random Testing
Posted: Fri Oct 19, 2012 12:18 am
hi,
I am Eviews 7 user and now I am doing a panel regression with this software. My data set includes 3 countries for 46 years(1963-2008). The form of my function is:
Y?=C+a*log(x1?)+b*log(x1?)^2+c*log(x1?)^3+d*log(x3?), the intercept "C" is expected to be cross section sepicfic.
My procedure goes like this:
Firstly, I run the "Unit root test". Since the result of this test show my data does not have a unit root, I turned to the next step of fixed/random effect model selection.Unfortunately, I encountered some problems in using the build-in function of Fixed/Random Testing.
There are two testing funcions for fixed/random selection,"Redundant Fixed Effects - Likelihood Ratio" and "Hausman Test for Correlated Random Effects", to perform the latter test, I need to estimate my model with your random effects specification.But once I select the "random" choice in Estimation method, Eviwes refuses to run estimation and the following warning has been given: "Random effect estimation requires number of cross section > number of coefs between estimator for estimate of RE innovation varaince". How can I solve this problem?
Du
Du
