Johansen Test - error or lags limit
Den
Postby Den » Wed Oct 17, 2012 12:55 am
Hi All,
I'm using EViews 7 Standard Edition Jan 7 2010 build.
I'm coding daily rolling Johansen Test on intraday (1 minute) data.
I declare var, freeze output window, put required data into scalar and save data from scalar to table.
However, I get "insufficient number of observations" message when script goes to 83 lags.
I tried declaring and freezing all the data at once, like
var series1_series2_vec1.ec 1 1 series1 series2
var series1_series2_vec2.ec 1 2 series1 series2
var series1_series2_vec123.ec 1 123 series1 series2
As well as to run through the data, i.e. declaring and freezing X vars for Y lags like
var series1_series2_vecX.ec 1 Y series1 series2
I also tried overwrite modes and deleting unnecessary items to save memory.
This doesn't seem to help.
Declaring goes fine, like >> var series1_series2_vec83.ec 1 83 series1 series2
But freezing causing the problem, like >> freeze(mode=overwrite, tab83) var series1_series2_vec83.ec 1 83 series1 series2
Everything before lag 83 runs fine, but from lag 83 I get "insufficient number of observations" message. I.e. for lags 84, 85, ... 90, etc.
Manually I can include lags I need, i.e. 1 83, 1 100, 1 200 etc. But I am unable to do this via program.
I played with options and advanced system options, but this had no effect.
Question 1: is there any hard coded restriction for number of lags (limit of 82?) in what I try to run?
Question 2: can you please suggest ways to include more lags?
