Automatic selection for DF GLS test
Posted: Tue Oct 09, 2012 3:42 am
by kiber_master
Hello
There is an option of automatic selection of lag length in Dickey-Fuller GLS test (depending on info criterion chosen). It seems that there is an inconsistency in results obtained.
Please find attached a workfile with a series of 26 elements (some of them are missing values). If I perform DFGLS test with automatic selection of lag length (with Akaike Info Criterion and max lags = 4) on this series I get the optimal lag equal to 3 with AIC =0.636060.
However, the value of AIC equals to 0.619124 for lag length=1, which is less than AIC for lag length=3 and is in fact the smallest value of AIC for lags = 0,1,2,3,4. This means that the automatic selection should have given us the optimal lag = 1, not 3.
Is this really a mistake in EViews calculations or maybe you use a different version of AIC for choosing an optimal lag length?
Re: Automatic selection for DF GLS test
Posted: Tue Oct 09, 2012 10:49 am
by EViews Glenn
Before I look at the attachment, a question: were you comparing the information criteria using the same samples?
Posted: Tue Oct 09, 2012 11:45 pm
by kiber_master
I didn't change the sample at all. 1-26.
Posted: Wed Oct 10, 2012 7:43 am
Which means you were using different samples, since each time you change the lag length, a different number of observations is chopped off from the start of the sample.
Posted: Wed Oct 10, 2012 9:36 pm
by kiber_master
So, for correct comparison I should estimate test on sample 6-26 for all lags, am I right?
Posted: Thu Oct 11, 2012 8:02 am
Yes.
