Econometrics - Differecing (on Eviews)!
Posted: Mon Oct 08, 2012 12:50 pm
First, I think it is good to refresh our memory about stationary data by quickly reading this short explanation: http://www.investopedia.com/articles/tr ... z27N8CsGCZ
In case you guys don't want to open the link. Here's the main part: "Using non-stationary time series data in financial models produces unreliable and spurious results and leads to poor understanding and forecasting. The solution to the problem is to transform the time series data so that it becomes stationary"
We can do so by differencing.
I have to be honest and say my knowledge of econometrics is very very limited and that's why I humbly come here to seek propoer technical advice.
Here is the issue. My Dependent variable IS stationary, but my Independent variables are NOT Stationary. When building models/equations on, let's say, eviews, can I keep my dependent variable just with the logarithmic form and my independent variables differencing the logarithms?
Here's JUST AN EXAMPLE of how the equation specification on eviews would look like:
ls logY c dlog_X dlog_Z ar(1)
I hope I can receive some proper advice on this matter as quickly as possible. For some of you this is a walk in the park. I just need to know if leaving the dependent variable without differencing would be ok or not acceptable. In case it is not, what is the way out? (do both sides HAVE to be differenced then?)
Thanks a lot in advance.
