I am estimating Garch equation for CBOE VIX index values.
In this regard i have some questions?
1. Can i take the dependent variable as log returns of VIX?
2. Do i need to set the Restirction to VarianceTarget or None ?
3. Is it correct that by setting restriction to variance target it ensure that gamma = 1 - alpha - beta
4. what is the significane of setting restriction to none
GARCH(1,1) Estimation
Re: GARCH(1,1) Estimation
If you are interested in the return of the VIX index, then it would make sense to have that as the dependent variable.
I have no idea as far as restrictions as I don't know what you are trying to accomplish.
However, modeling VIX as the dependent variable in a GARCH model would be a way of evaluating the volatility of volatility. This would be a relevant question wr option market behavior.
ophadnavis
Hi Jim,
Thanks for your help. In the eview software there is a parameter to be set for Restrictions (See the attachment). I am not able to understand if which of the options is to be selected "none" or "Igarch" or "variance target".
Please suggest
Regards
Onkar
Please suggest
Regards
Onkar
- Eview garch.png (58.29 KiB) Viewed 4559 times
