I've found mpalmi had the same problem with me. I have only 558 oberservations but the sheet would always tell me that there are 751. Eviews would set the number after 558 zero. This REALLY matters because it affects the mean of the variable and the regression.
Thanks all!
why the sample size is fixed to 751?
- 1_副本.png (117.88 KiB) Viewed 1811 times
Re: why the sample size is fixed to 751?
I think you are trying to edit the coefficent vector "C" in the workfile. If you have undated observations, then you can create an integer dated workfile:
And then, you can create/generate your own series in the workfile:
You should enter the values into this series.
wfcreate u 558Code: Select all
series myserWho is online
