P-values in DFGLS
Posted: Tue Sep 11, 2012 6:52 am
by evropeec
I am running a bunch of unit root test and storing the results in a vector using the "save" option. Unlike ADF output, however, this option does not store the p-values for the DFGLS test in the fourth element of the output vector, even though the p-vlaue is reported in the series window's unit root view. I'd really appreciate it if there's an easy way to work around this issue, without copying the p-value from individual unit root views. Thanks!
Re: P-values in DFGLS
Posted: Tue Sep 11, 2012 1:33 pm
by EViews Glenn
Which version of EViews are you using?
Posted: Wed Sep 12, 2012 6:18 am
by evropeec
I'm using Eviews 7.1; thanks.
Posted: Wed Sep 12, 2012 9:36 am
by EViews Glenn
I don't see where the DFGLS p-values are displayed...
Posted: Wed Sep 12, 2012 11:51 am
by evropeec
Sorry--that was due to the alternating use of tau and t-statistics in the notes that I had. Anyway, it would be great if the p-value could be added to output, including using the save option.
Thank you.
Posted: Wed Sep 12, 2012 1:48 pm
by EViews Glenn
There is no p-value. Only the tablulated critical values. To the best of my knowledge, there have not been any published response surface approximations to the tabulated values, which is why there are no p-values.
Posted: Thu Sep 13, 2012 6:15 am
by evropeec
Thanks for clarifying this. It would be great if the critical values could be added to the output file, so that comparing test stats to them can be carried out without looking at the individual series' windows.
Posted: Fri Sep 14, 2012 3:44 pm
by EViews Glenn
I'll make a note of the suggestion. Thanks.
