v6 and v7.1
Posted: Fri Aug 10, 2012 4:42 am
by cel
i'm using two version (7.1 Mar 21 2011 build) and (6, Sep 3 Build).
I now find that when i estimate a pre-saved eqn system under 6 i get fine results, but when i open up the identical wf1 file and do the identical estimation (in fact i save the estimation window so it's just re-running the same object), i get the error message: "No Valid observations in ... ", which is clearly crazy since it's easy to see that all the data is still there.
Previously i actually got both versions to work, but now only 6 will work. can i send anyone my wf1 to check this really annoying problem.
Thanks.
Re: v6 and v7.1
Posted: Fri Aug 10, 2012 6:55 am
Is your equation nonlinear? If so, the initial values in the C vector matter.
Re: v6 and v7.1
Posted: Fri Aug 10, 2012 7:07 am
by cel
yes, correct: the system is non linear.
but notwithstanding in the wf1 file there is a
param c(1) ...
line that is identical in both cases (i.e, the file ran under v7.1 and v6).
Re: v6 and v7.1
Posted: Fri Aug 10, 2012 7:27 am
The no valid observations sometimes happens because particular parameter values cause a divide by zero or something similar. But it sounds like you should have that covered.
What you're seeing does sound a little odd. It's a bit of a long shot, but you might want to update your EViews 7 to the current version.
Re: v6 and v7.1
Posted: Fri Aug 10, 2012 8:04 am
If updating both copies to the latest version doesn't fix it, please post the workfile.
