Logit and Probit Regression
Posted: Wed Jul 18, 2012 8:05 am
by RoaStudent1984
Can someone please tell me how to run a probit and logit regression with Eviews?
I have absolutely no clue how the program works, and need these regressions to finish my thesis.
Both Regressions need to be run on 363(Date of Data) *10 (variables) data items.
For the Probit Regression I have:
- 6 independent control variables and 4 dummy variables.
- Dependent variables are valuation models used by brokers (0=Multiple, 1=DCF)
For the Logit Regression I have:
- Dependent variables are valuation models used by brokers (1=Multiple, 2=DCF, 3=SOP)
Thanks in advance!
Re: Logit and Probit Regression
Posted: Wed Jul 18, 2012 11:10 am
Do you already have your data in EViews? Which parts of the manual have you looked at?
Posted: Fri Jul 20, 2012 4:49 am
by RoaStudent1984
Yes my data is in Eviews and I found in the manual that I have to select the binary estimation method from the equation objects.
When I enter my equation specification the displayed information shows NA for St.Error, Z-statistic and Prob.
Posted: Fri Jul 20, 2012 7:01 am
Do you get a warning message on the equation output?
Posted: Mon Jul 30, 2012 1:46 am
by RoaStudent1984
There is indeed a warning message:
Singular covariance - coefficients are not unique
Covariance matrix computed using second derivatives
My equations input is as follows:
valuation_model c volatility size growth leverage mkt_bk r_d @expand(industrysector) @expand(industrysubgroup) @expand(cyclical) @expand(broker)
The regression output gives no warning when I leave the dummy variables out of the equation...
Posted: Mon Jul 30, 2012 6:27 am
Dummy variable trap.
Posted: Mon Jul 30, 2012 7:31 am
by RoaStudent1984
If I leave the constant out of the equation I get the following error message:
Non-positive likelihood value for observation 1
Posted: Mon Jul 30, 2012 7:53 am
See what happens if you only use one @expand statement at at time.
Posted: Mon Jul 30, 2012 9:01 am
by RoaStudent1984
It works when I only use one @expand statement at at time.
Does this effect the outcome of the regression if I have to perform them seperately instead of at once?
Posted: Mon Jul 30, 2012 9:04 am
The problem is that you are falling into the dummy variable trap with multiple categories of dummies. Basically, you need to drop one dummy from each category.
Posted: Tue Jul 31, 2012 8:42 am
by RoaStudent1984
Shouldn't I then just rewrite the equation so that every dummy is seperate?
So @recode(MS,1,0) @recode(CS,1,0) @recode(3510,1,0) @recode(3520,1,0) etc?
Posted: Tue Jul 31, 2012 8:43 am
No. Look at the @drop options in @expand
Posted: Tue Jul 31, 2012 9:30 am
by RoaStudent1984
I tried the following:
@expand(industry, @dropfirst) but then I get the same error message as in the beginning.
Posted: Tue Jul 31, 2012 9:32 am
Try googling "dummy variable trap"
Posted: Thu Aug 02, 2012 3:00 am
by RoaStudent1984
Thanks for all the help! The probit model is now completed.
Next step is that I have to run a multinomial logit regression.
The dependent variable can be either one of three choices where 1 is the reference point.
The dependent variable is followed by a set of independent variables (regressors?).
How do I have to create the equation so that I get values for both 2nd and 3d choice in one single output model?
