Haussmann Test
Muhanad
Haussmann Test
Postby Muhanad » Mon Jul 16, 2012 12:41 pm
I have tried the Haussmann test on my eviews data file but have recieved the error in the test results stating "Cross section test variance invalid. Haussmann statistic is set to zero." The attached file includes the data and test result in question. Any comments or advice will be much appreciated.
- muhanad
hdi.wf1
HDI file
(35.71 KiB) Downloaded 209 times
Re: Haussmann Test
Postby EViews Gareth » Mon Jul 16, 2012 12:59 pm
Muhanad
Re: Haussmann Test
Postby Muhanad » Mon Jul 16, 2012 1:13 pm
Thank you!
Muhanad
Re: Haussmann Test
Postby Muhanad » Wed Jul 18, 2012 5:41 am
As a follow up; given the above test results, will a constant coeffiencent (pool) model suffice? That is, instead of selecting random or fixed in the drop-down option.
Re: Haussmann Test
Postby EViews Glenn » Wed Jul 18, 2012 11:12 am
That is not an implication of the result. The only thing you can take from it is that there is insufficient evidence to distinguish between the fixed and random effects models.
