Page 1 of 2
VIF analysis in Panel data
Posted: Mon Jul 02, 2012 11:15 pm
by khor1984
HI,
I tried to test multicolinearity for my panel data. Unfortunately, i am not able to find the button for VIF in EVIEW 7.
May i know if the function for VIF analysis is not available in panel data analysis? If it is so, is there any other test that can use to test multicolinearity?
Thanks..
Re: VIF analysis in Panel data
Posted: Tue Jul 03, 2012 5:43 am
by startz
Out of curiuosity, why do you want to test for multicollinearity?
Posted: Tue Jul 03, 2012 7:44 am
VIF is not available for panels, nor is any other multicolinearity statistic.
Posted: Tue Jul 03, 2012 11:29 pm
by khor1984
The reason i test for multicollinearity is to check whether there is correlation between my variables.. is there any test that i can use for testing multicollinearity in panel data? or, we are assuming no multicollinearity in panel data?
Posted: Wed Jul 04, 2012 6:57 am
by startz
Why do you care whether there is correlation between your variables? There almost certainly is correlation, but that's what OLS is built to sort out.
Posted: Wed Jul 04, 2012 10:10 pm
by yasir
I just want to say something on Gareth's comment. You said none of the tests for multicollinearity is included in Eviews. But I have been able to use the VIF for panel data. I estimate an equation, give the equation a name and then type "eq01.varinf" and it gives me the varinace inflation factor both centered and uncentered (if constant is included). Isn't that a test for multicollinearity?
Posted: Wed Jul 04, 2012 10:27 pm
ok, VIFs shouldn't be available for panel equations :D
Posted: Mon Jun 10, 2013 5:18 pm
by Cabinho
This is probably not set in stone but can somebody explain what is the rule of thumb for uncentered and centered VIF in cross sectional data?
Posted: Wed Nov 27, 2013 1:11 pm
by franciscoA
Can you explain a little bit this sentence. Is multcollinearity irrelevant in panel equations?
Posted: Wed Nov 27, 2013 1:13 pm
EViews doesn't offer VIF analysis for panel data. That's all that statement meant.
Posted: Wed Nov 27, 2013 1:23 pm
by franciscoA
Thank you. Can you explain why? Is Eviews planning to include this test or any other tests related to multicollinearity for panel in the future? What would you recommend if I want to consider multicollinearity in the analysis I'm performing using EViews?
Posted: Wed Nov 27, 2013 1:24 pm
There was no particular reason why. The computation of VIF in panels are slightly different, that's all.
Posted: Wed Nov 27, 2013 1:33 pm
by franciscoA
No plans for the future?
Posted: Wed Nov 27, 2013 1:43 pm
Not currently.
Posted: Tue Mar 24, 2015 11:48 pm
by saizal87
You can actually test for multicollinearity based on VIF on panel data. lets say the name of your equation is eq01, so type "eq01.varinf" and then click enter. then you will get centered (with constant) vif and uncentered (without constant) vif. Keep in mind, if your equation dont have constant, then you will only get the uncentered.
