How do I enter categorical dummy variables into a logit model? I have constructed ten categories from a set of 2-digit industry codes (<10, 10-19, 20-29, and so on). I am able to run these on our performance measure using OLS and the @expand command, but when trying to do the same thing with the logit model I get the message "unmatched parenthesis". Is there some way to get around this problem?
Thank you for your help!
Categorical dummy variable in logit model
Re: Categorical dummy variable in logit model
Could you provide your workfile? It should work in exactly the same way as for OLS.
