panel data regression with exponential form
Sima
Postby Sima » Fri Jun 22, 2012 3:21 am
I want to know how can I run a panel data regression with exponential form? I've been told that the formula ls y = c(1) + exp(c(2)*x) doesn't work for panel data.Is it correct?
Postby EViews Gareth » Fri Jun 22, 2012 6:32 am
What is the form of the equation you're trying to estimate?
Re: panel data regression with exponential form
Postby EViews Glenn » Fri Jun 22, 2012 10:52 am
And what is your error specification and how does the panel nature of the data enter into the spec.
Sima
Postby Sima » Fri Jun 22, 2012 9:57 pm
My equation is u=e^av where u is unemployment rate and v is vacancy rate.I ran u=c(1)+exp(c(2)*v) and it worked without any error .but my teacher said that it's not correct because it doesn't consider the fixed and random effect.I don't understand why?
Postby EViews Gareth » Fri Jun 22, 2012 10:14 pm
Did you include fixed or random effects?
Sima
Postby Sima » Fri Jun 22, 2012 10:33 pm
yes,I included fixed effects.
Postby EViews Glenn » Mon Jun 25, 2012 10:30 am
Any fixed effects added to the specification will be as a linear term added to the end of your nonlinear specification. Estimation is done in the usual fashion for fixed effects by iterating the linearized specification to convergence.
