read me please! multinomial logit
Posted: Sat Mar 28, 2009 9:36 am
by cocoabutter
Hello!
I need some help please!
My question is, how do I estimate a multinomial logit regression in eviews? I had a look at the estimate equation function, but it only offers binary logit.
Also, are there any additional considerations ( things to note) if one is running multinomial logits on panel/pool data?
Thank you very very much
Ali
Re: read me please! multinomial logit
Posted: Sat Mar 28, 2009 10:05 am
Hello!
Ali
To get started, you might search the help files for "multinomial"
Posted: Mon Mar 30, 2009 8:58 am
There is an example program for using the LogL object to estimate a multinomial logit (Help/Quick Help Reference/Sample Programs & Data/Logl).
As to the panel issue, it really depends on what kinds of structure you want to put on your problem. The sample program above is non-panel aware, and depending on what you wish to assume, there may be changes that you need to make.
Posted: Tue Mar 31, 2009 3:28 pm
by cocoabutter
many thanks¬
Posted: Tue Jun 18, 2013 10:26 am
by Cabinho
Hi Glenn,
I have a multinomial categorical dependent variable model I want to run for cross sectional data.
I used logistic distribution, uncensored and no truncation under the "censored - censored or truncated data (including tobit)" method option.
Could this be another way of estimating a mutinomial logit?
Posted: Tue Jun 18, 2013 10:30 am
No, it is not.
Posted: Tue Jun 18, 2013 12:11 pm
by Cabinho
No, it is not.
If my dependent variable has values of 0,1,2 and 3 and I use logistic regression under the censored methods but I use left censor 0 and no right censor. No truncation.
Am I converting the dependent variable in 0,1 where 1 can be 1,2 and 3?
Thank you Glenn
Posted: Tue Jun 18, 2013 1:46 pm
The censored regression tools assume that the non-censored responses are continuously observed and that the censoring portions are due to the latent hitting threshold values.
