different results on different computers
schwert
Postby schwert » Thu May 31, 2012 9:47 am
My son and I both use Eviews 7.1 on window 7 64 bit machines, but we get different estimation results from regressions with ARMA errors (Non-linear least squares) When I estimate the models he has run I get the same results as when I estimate the models I have run, and he sees the same thing (which is not surprising, because we think we are estiamting the same model), but the results he gets on his computer are different than the results I get on two different machines that I use.
this is really puzzling .. .
I can send the eviews workfile if that would help
Re: different results on different computers
Postby EViews Gareth » Thu May 31, 2012 10:29 am
Check you are using the same version of EViews (really there's no reason for either of you to be using EViews 7.1!).
Also check you are using the same starting values.
Rits
Postby Rits » Mon Jul 09, 2012 2:24 pm
When you say "same starting values" are you refering to using the same first value of the sample being used?
Postby EViews Gareth » Mon Jul 09, 2012 2:47 pm
No. When performing non-linear estimation (such as ARMA), you need numerical starting values for the coefficients. Different starting values can yield different final estimates. In general EViews obtains starting values from the C vector in the workfile.
Rits
Postby Rits » Mon Jul 09, 2012 2:49 pm
Ok so it's the value of the C vector. I'll give it a shot. Thanks Gareth!
