Confused About Simple VAR LM Test
vtov
Postby vtov » Thu Apr 26, 2012 8:03 am
VAR Residual Serial Correlation LM Tests
Null Hypothesis: no serial correlation at lag order h
Date: 04/26/12 Time: 15:57
Sample: 1961M01 2010M12
Included observations: 594
Lags LM-Stat Prob
1 33.80490 0.1121
2 31.13447 0.1846
3 53.37381 0.0008
4 51.58304 0.0014
5 33.08849 0.1289
6 33.04551 0.1299
7 41.86553 0.0186
Probs from chi-square with 25 df.
Say, if VAR estimated is VAR(6), does this means my VAR model has no autocorrelation problem at all with p=0.1299 or this means my VAR model has autocorrelation problem at lag 3 and 4 but not the other lags?
Help very much appreciated! Also, is the test dependent on normally distributed errors?
leybert
Re: Confused About Simple VAR LM Test
Postby leybert » Thu Jul 26, 2012 9:01 am
Hello, I am not quite sure if there is a response to that but I am wondering the same thing?
Shuyilim0619
Postby Shuyilim0619 » Fri May 24, 2013 12:14 pm
If the more than half of the p values exceed 0.05 or 0.1... Then can consider the result is no autocorrelation
alexyflemming
Postby alexyflemming » Thu Oct 31, 2013 1:54 am
I am wondering the same thing.
To the answer "more than half of p values >0,05, then no autocorrelation" ===> I did not meet any such info in literature. Please give your source.
Also, Eviews output sometimes shows VAR Autocorrelation that, p values of some of the lags are <0,05 where some others >0,05.
So, Assume for example VAR(2) is estimated, and VAR Autocorrelation test is done for lags up to 2. The output is:
Lag p
1 0,01
2 0,45
Then what will be our decision?
a. we are working with VAR(2), and hence p=0,45>0,05. ==> No autocorrelation for VAR residuals
OR
b. There is a p=0,01<0,05, and hence VAR(2) is problematic in terms of residual autocorrlations?
Any help will be appreciated much.
engur
Postby engur » Tue Mar 31, 2015 11:03 am
I am wondering the same thing!!! can any expert send a reply please ?
Thewad
Postby Thewad » Thu Jul 16, 2015 7:11 am
I have similar problem, also. So, it would be really nice if someone can help us here.
Thanks in advance.
