Launch E-Views via C#; submit .prg file
Posted: Wed Apr 25, 2012 11:00 pm
by roorooroo
Can anyone comment on the following problem:
-- I need to launch E-Views from a C# application
-- After E-Views is open, I need to submit a .prg command file to E-Views via the C# application
The .prg file, which is already prepared and works, asks E-Views to open a .wf1 file, import information from a text file to add an additional observation to the .wf1 file, estimate an ARIMA model, forecast the next observation, write the forecast to a text file, save the .wf1 file and then exit E-Views.
Re: Launch E-Views via C#; submit .prg file
Posted: Tue Dec 22, 2015 8:20 am
by DannyB
I'm looking for the same issue, do you find any solutions?
Regards,
DannyB
Posted: Tue Dec 22, 2015 10:54 am
by EViews Steve
From C# (or any .NET programming language) you can simply run the EViews executable and pass the path to your PRG file as a parameter, like this:
"C:\Program Files (x86)\EViews 9\EViews9.exe" "c:\files\my.prg"
This example launches EViews 9 32-bit and automatically runs the specified program.
You can also use our COM Automation interface to instantiate an EViews Application object, then pass a RUN command with the path to your program file. To become familiar with using EViews COM Automation, read this whitepaper from our Downloads page.
