Creating Dummies for calendar effects (2)
trubador
Did you use forum search?
Re: Creating Dummies for calendar effects (2)
Postby trubador » Wed Apr 25, 2012 3:58 am
There is more than one way to do that. Below you can find two of them:
%may = "05/01 05/02 05/03" %oct= "09/30 10/01 10/02 10/03 10/04 10/05 10/06" series dum1 = 0 series dum2 = 0 for !i = 1 to @wcount(%may) dum1 = @recode(@datestr(@date,"MM/DD")=@word(%may,!i),1,dum1) next for !j = 1 to @wcount(%oct) dum2 = @recode(@datestr(@date,"MM/DD")=@word(%oct,!j),1,dum2) next
%may = "05/01 05/02 05/03" %oct= "09/30 10/01 10/02 10/03 10/04 10/05 10/06" series dum1 = 0 series dum2 = 0 smpl if @datestr(@date,"MM/DD")>=@wleft(%may,1) and @datestr(@date,"MM/DD")<=@wright(%may,1) dum1 = 1 smpl if @datestr(@date,"MM/DD")>=@wleft(%oct,1) and @datestr(@date,"MM/DD")<=@wright(%oct,1) dum2 = 1 smpl @all
Sissy
Postby Sissy » Wed Apr 25, 2012 4:58 am
Thanks a lot for these 2 codes.
However,the first code did not work because the Eviews 7 Student Version does not provide programs apparently.
So I tried the second code, but an error message tells me "Error in the sample: the %MAY is not defined ". Could you help me to resolve this problem, please ?
Thanks in advance.
trubador
Postby trubador » Wed Apr 25, 2012 5:50 am
This should work:
string may = "05/01 05/02 05/03" string oct= "09/30 10/01 10/02 10/03 10/04 10/05 10/06" series dum1 = 0 series dum2 = 0 smpl if @datestr(@date,"MM/DD")>=@wleft(may,1) and @datestr(@date,"MM/DD")<=@wright(may,1) dum1 = 1 smpl if @datestr(@date,"MM/DD")>=@wleft(oct,1) and @datestr(@date,"MM/DD")<=@wright(oct,1) dum2 = 1 smpl @all
Sissy
Postby Sissy » Wed Apr 25, 2012 5:56 am
Thanks a lot. It totally works :lol:
Sissy
Postby Sissy » Fri Apr 27, 2012 12:04 am
I have another problem considering non-fixed holiday periods:
I need to regress daily (7 weekdays) prices against some monetary policy variables. But in my regression, calendar effects have to be controled. Calendar effects correspond to Chinese holidays. In order to take calendar effects into account, I'd like to create a dummy variable,taking the value 1, for the following Chinese holidays (MM/DD/YYYY) which are not the same for each year:
02/06/2008, 02/07/2008, 02/08/2008, 02/09/2008, 02/10/2008, 02/11/2008, 02/12/2008, 01/25/2009, 01/26/2009, 01/27/2009, 01/28/2009, 01/29/2009, 01/30/2009, 01/31/2009, 02/13/2010, 02/14/2010, 02/15/2010, 02/16/2010, 02/17/2010, 02/18/2010 and 02/19/2010 .
My daily (7 weekdays) sample runs from 12/01/2007 to 04/27/2010.
Could you help me to resolve my problem, please ?
Thanks.
EViews Esther
Postby EViews Esther » Fri Apr 27, 2012 8:57 am
This will work.
%holidays= "02/06/2008 02/07/2008 02/08/2008 02/09/2008 02/10/2008 02/11/2008 02/12/2008 01/25/2009 01/26/2009 01/27/2009 01/28/2009 01/29/2009 01/30/2009 01/31/2009 02/13/2010 02/14/2010 02/15/2010 02/16/2010 02/17/2010 02/18/2010 02/19/2010" series dummy = 0 for !i = 1 to @wcount(%holidays) dummy = @recode(@datestr(@date,"MM/DD/YYYY")=@word(%holidays,!i),1,dummy) next smpl @all
