Panel help
Posted: Mon Apr 16, 2012 12:18 pm
Dear Gareth and other Eviews helpers,
My data almost looks identical to those of the second format. I managed to import them in Eviews.
I have my dependent variable (abnormal_return) and several explanatory variables (trade, fina,...), each for 66 countries (cross-section) for 2 years (period).
Now I want to run simple regressions with them like abnormal_return c trade (both of which are expressed in percentages).
I was warned however about the existence of fixed effects for the panel variable.
Therefore, I ran the regression with fixed effects for both period (2) & cross-section (66), did the Redundant Fixed Effect - Likelihood Test and I obtain fixed effects for both.
The problem now is, when I run the regression with "none" (no fixed effects, no random), then I more or less get the results I want. The results with "fixed" for both period and cross-sections just isn't realistic. The output states if trade goes up with 1%, the abnormal return decreases with almost 4%. That just isn't possible!
Is it possible I should adjust something (f.e. only fixed for period?).
Please take a look at my attachments, you would help me enourmosly.
