Stacking bug
Posted: Thu Apr 12, 2012 2:08 am
by rousing
I have encountered a possible bug when stacking and unstacking variables in Eviews. The error has only surfaced in the past month and I suspect this was after I installed the patch from March. In am currently using Eviews 7.2 with the patch from April.
Anyways, my problem is the following: When I stack a number of variables and make a forecast in panel framework - then my forecast are for some reason not recognized when unstacking these again. I have tried to exemplify the problem with the attached workfile and program.
Thank you in advance for your assistance.
Best regards
Rasmus
Re: Stacking bug
Posted: Thu Apr 12, 2012 7:56 am
Note a bug, rather a "feature". When unstacking, EViews will automatically determine whether a variable is a panel variable or a non-panel variable, with the difference being "does this variable have any difference between cross-sections". If there is no difference between cross-sections, EViews will only unstack it into one variable, since it seems pointless to create many variables that are all identical.
Re: Stacking bug
Posted: Thu Apr 12, 2012 8:24 am
by rousing
thanks for the prompt reply. I am a bit puzzled why all the forecast are identical - are the fixed effects not taken into account when generating the forecast?
Re: Stacking bug
Posted: Thu Apr 12, 2012 10:26 am
Good point, we're looking in to it.
Re: Stacking bug
Posted: Fri Apr 13, 2012 1:54 pm
Grab the latest patch. Should fix it for you.
Re: Stacking bug
Posted: Fri Apr 13, 2012 2:12 pm
by rousing
Great, thank you very much for your assistance :)
