Graph object
Posted: Wed Apr 04, 2012 5:37 pm
by tchaithonov
Hey Guys, how are you?
I have been writing a program that creates a graph object at first run and check if that object exists (using @isobject()) in subsequent runs, but since I sometimes want to look only at the resid and other times the Dep Var + resid, I run into trouble when trying to show the latter option (the graph only shows resid with the updated options). There doesn't seem to be an easy way to clear the variables within a graph object (since graph reset doesn't mean what I think it means), and I really don't want to delete graph and re-create the graph object during every single run (because the window would be jumping around the screen). I could have used a graph functions in a group object to do the same thing, but I want to change the backcolor and drop the legend inbox, which leaves me with the graph object option. Any ideas would be helpful. Thanks.
Tchaithonov
Graph object
Posted: Wed Apr 04, 2012 8:37 pm
You can't remove or add variables to graph object.
