state space estimation
Posted: Fri Mar 23, 2012 7:23 am
Hi, I'm tring to replicate the paper:" The Macroeconomy and the yield curve: a dynamic latent factor approach", in which the yield curve is summarized using latent factors (level=sv1, slope=sv2 and curvature=sv3). I have no estimation problems with the first specification, only with latent factor:
@signal y_3 =sv1+(( 1-exp(-c(28)*3)) / (c(28)*3))*sv2+((( 1-exp(-c(28)*3)) / (c(28)*3)) - ( exp(-c(28)*3)))*sv3+[ename=e_3]
@signal y_12=sv1+(( 1-exp(-c(28)*12))/(c(28)*12))*sv2+((( 1-exp(-c(28)*12))/(c(28)*12))-( exp(-c(28)*12)))*sv3+[ename=e_12]
@signal y_24=sv1+(( 1-exp(-c(28)*24))/(c(28)*24))*sv2+((( 1-exp(-c(28)*24))/(c(28)*24))-( exp(-c(28)*24) ))*sv3+[ename=e_24]
@signal y_36 =sv1+(( 1-exp(-c(28)*36))/(c(28)*36))*sv2+((( 1-exp(-c(28)*36))/(c(28)*36))-(exp(-c(28)*36)))*sv3+[ename=e_36]
@signal y_60 =sv1+((1-exp(-c(28)*60))/(c(28)*60))*sv2+((( 1-exp(-c(28)*60))/(c(28)*60))-( exp(-c(28)*60)))*sv3+[ename=e_60]
@signal y_84 =sv1+(( 1-exp(-c(28)*84))/(c(28)*84))*sv2+((( 1-exp(-c(28)*84))/(c(28)*84))-( exp(-c(28)*84) ))*sv3+[ename=e_84]
@signal y_120=sv1+(( 1-exp(-c(28)*120))/(c(28)*120))*sv2+((( 1-exp(-c(28)*120))/(c(28)*120))-( exp(-c(28)*120)))*sv3+[ename=e_120]
@signal y_360=sv1+(( 1-exp(-c(28)*360))/(c(28)*360))*sv2+((( 1-exp(-c(28)*360))/(c(28)*360))-( exp(-c(28)*360)))*sv3+[ename=e_360]
@state sv1 = c(10) + c(1)*( sv1(-1) - c(10) ) + c(2)*( sv2(-1) - c(11) ) + c(3)*( sv3(-1) - c(12) ) + [ename=ni_l]
@state sv2 = c(11) + c(4)*( sv1(-1) - c(10) ) + c(5)*( sv2(-1) - c(11) ) + c(6)*( sv3(-1) - c(12) ) + [ename=ni_s]
@state sv3 = c(12) + c(7)*( sv1(-1) - c(10) ) + c(8)*( sv2(-1) - c(11) ) + c(9)*( sv3(-1) - c(12) ) + [ename=ni_c]
@evar var(ni_l)=exp(c(13))
@evar var(ni_s)=exp(c(14))
@evar var(ni_c)=exp(c(15))
@evar cov(ni_l,ni_c)=c(16)
@evar cov(ni_s,ni_c)=c(17)
@evar cov(ni_l,ni_s)=c(18)
@evar var(e_3)=exp(c(19))
@evar var(e_12)=exp(c(21))
@evar var(e_24)=exp(c(22))
@evar var(e_36)=exp(c(23))
@evar var(e_60)=exp(c(24))
@evar var(e_84)=exp(c(25))
@evar var(e_120)=exp(c(26))
@evar var(e_360)=exp(c(27))
When I try to add 3 macro variable Capacity utilization(cu), annual price inflation(cpi) and fed fun rate(fed) in this way:
@state sv1 = c(37) + c(1)*( sv1(-1) - c(37) ) + c(2)*( sv2(-1) - c(38) ) + c(3)*( sv3(-1) - c(39) ) + c(4)*(cu(-1) - c(40)) + c(5)*(fed(-1) - c(41)) + c(6)*(cpi(-1) - c(42)) + [ename=ni_l]
@state sv2 = c(38) + c(7)*( sv1(-1) - c(37) ) + c(8)*( sv2(-1) - c(38) ) + c(9)*( sv3(-1) - c(39) ) + c(10)*(cu(-1) - c(40)) + c(11)*(fed(-1) - c(41)) + c(12)*(cpi(-1) - c(42)) + [ename=ni_s]
@state sv3 = c(39) + c(13)*( sv1(-1) - c(37) ) + c(14)*( sv2(-1) - c(38) ) + c(15)*( sv3(-1) - c(39) ) + c(16)*(cu(-1) - c(40)) + c(17)*(fed(-1) - c(41)) + c(18)*(cpi(-1) - c(42)) + [ename=ni_c]
@state cu = c(40) + c(19)*( sv1(-1) - c(37) ) + c(20)*( sv2(-1) - c(38) ) + c(21)*( sv3(-1) - c(39) ) + c(22)*(cu(-1) - c(40)) + c(23)*(fed(-1) - c(41)) + c(24)*(cpi(-1) - c(42)) + [ename=ni_cu]
@state fed = c(41) + c(25)*( sv1(-1) - c(37) ) + c(26)*( sv2(-1) - c(38) ) + c(27)*( sv3(-1) - c(39) ) + c(28)*(cu(-1) - c(40)) + c(29)*(fed(-1) - c(41)) + c(30)*(cpi(-1) - c(42)) + [ename=ni_fed]
@state cpi = c(42) + c(31)*( sv1(-1) - c(37) ) + c(32)*( sv2(-1) - c(38) ) + c(33)*( sv3(-1) - c(39) ) + c(34)*(cu(-1) - c(40)) + c(35)*(fed(-1) - c(41)) + c(36)*(cpi(-1) - c(42)) + [ename=ni_cpi]
I'm not able to get convergence in the estimation process. Can you help me please?
