Problem Saving Estimated VAR Coefficients
Posted: Fri Mar 16, 2012 8:53 am
by mike_d
I am looping through many files, running a VAR or VEC based on whether there is a cointegrating relation. I am currently trying to properly store all estimated coefficients and standard errors. I have referred to the help files and figure what I am attempting is the most efficient way. I have included a small snippet of the step that estimates and saves coefficients for VAR/VEC with 2 lags. The problem I am having is that the estimated VAR coefficients are not saving properly. For some reason the estimate for the first lag of the second endogenous variable (s9, s11 or s13 in this case) is not saving in the correct position in my results table. I have contemplated freezing the estimating as a table and then taking the value from the frozen table but would like to know where I am going wrong. I can upload the entire program if needed however it is quite long. Thanks in advance. See code below, I commented on the specific lines that are not working the way I thought they would:
if cdsv = 2 then
for !w = 9 to 14 step 2
!older = @errorcount
if c!w = 0 then
var var_est!w.ls 1 2 s3 s!w @ s15 s16 s17 s18 s19
endif
if c!w > 0 then
var vec_est!w.ec 1 2 s3 s!w @ s15 s16 s17 s18 s19
endif
!newer = @errorcount
if !newer = !older then
clearerrs
var!w_coeff1(!i*3,1) = var_est!w.c(1,1)
var!w_coeff1(!i*3,2) = var_est!w.c(1,2)
var!w_coeff1(!i*3,5) = var_est!w.c(1,3) '''not working - saving the same coeff as line above for some reason instead of coeff 3 (1st lag of second endog.)
var!w_coeff1(!i*3,6) = var_est!w.c(1,4)
''exogs
var!w_coeff1(!i*3,9) = var_est!w.c(1,5) '''these 5 lines save coeff 3-7 from eq1 but I want coeff 5-9 saved in these spots
var!w_coeff1(!i*3,10) = var_est!w.c(1,6)
var!w_coeff1(!i*3,11) = var_est!w.c(1,7)
var!w_coeff1(!i*3,12) = var_est!w.c(1,8)
var!w_coeff1(!i*3,13) = var_est!w.c(1,9)
var!w_coeff1(!i*3,14) = var_est!w.c(2,1)
var!w_coeff1(!i*3,15) = var_est!w.c(2,2)
var!w_coeff1(!i*3,18) = var_est!w.c(2,3)
var!w_coeff1(!i*3,19) = var_est!w.c(2,4)
''exogs
var!w_coeff1(!i*3,22) = var_est!w.c(2,5)
var!w_coeff1(!i*3,23) = var_est!w.c(2,6)
var!w_coeff1(!i*3,24) = var_est!w.c(2,7)
var!w_coeff1(!i*3,25) = var_est!w.c(2,8)
var!w_coeff1(!i*3,26) = var_est!w.c(2,9)
var!w_coeff1((!i*3)+1,1) = var_est!w.@coefse(1,1)
var!w_coeff1((!i*3)+1,2) = var_est!w.@coefse(2,1)
var!w_coeff1((!i*3)+1,5) = var_est!w.@coefse(3,1)
var!w_coeff1((!i*3)+1,6) = var_est!w.@coefse(4,1)
''exogs
var!w_coeff1((!i*3)+1,9) = var_est!w.@coefse(5,1)
var!w_coeff1((!i*3)+1,10) = var_est!w.@coefse(6,1)
var!w_coeff1((!i*3)+1,11) = var_est!w.@coefse(7,1)
var!w_coeff1((!i*3)+1,12) = var_est!w.@coefse(8,1)
var!w_coeff1((!i*3)+1,13) = var_est!w.@coefse(9,1)
var!w_coeff1((!i*3)+1,14) = var_est!w.@coefse(1,2)
var!w_coeff1((!i*3)+1,15) = var_est!w.@coefse(2,2)
var!w_coeff1((!i*3)+1,18) = var_est!w.@coefse(3,2)
var!w_coeff1((!i*3)+1,19) = var_est!w.@coefse(4,2)
''exogs
var!w_coeff1((!i*3)+1,22) = var_est!w.@coefse(5,2)
var!w_coeff1((!i*3)+1,23) = var_est!w.@coefse(6,2)
var!w_coeff1((!i*3)+1,24) = var_est!w.@coefse(7,2)
var!w_coeff1((!i*3)+1,25) = var_est!w.@coefse(8,2)
var!w_coeff1((!i*3)+1,26) = var_est!w.@coefse(9,2)
vec!w_coeff1(!i*3,2) = vec_est!w.c(1,1)
vec!w_coeff1(!i*3,3) = vec_est!w.c(1,2)
vec!w_coeff1(!i*3,6) = vec_est!w.c(1,3)
vec!w_coeff1(!i*3,7) = vec_est!w.c(1,4)
''exogs
vec!w_coeff1(!i*3,10) = vec_est!w.c(1,5)
vec!w_coeff1(!i*3,11) = vec_est!w.c(1,6)
vec!w_coeff1(!i*3,12) = vec_est!w.c(1,7)
vec!w_coeff1(!i*3,13) = vec_est!w.c(1,8)
vec!w_coeff1(!i*3,14) = vec_est!w.c(1,9)
vec!w_coeff1(!i*3,16) = vec_est!w.c(2,1)
vec!w_coeff1(!i*3,17) = vec_est!w.c(2,2)
vec!w_coeff1(!i*3,20) = vec_est!w.c(2,3)
vec!w_coeff1(!i*3,21) = vec_est!w.c(2,4)
''exogs
vec!w_coeff1(!i*3,24) = vec_est!w.c(2,5)
vec!w_coeff1(!i*3,25) = vec_est!w.c(2,6)
vec!w_coeff1(!i*3,26) = vec_est!w.c(2,7)
vec!w_coeff1(!i*3,27) = vec_est!w.c(2,8)
vec!w_coeff1(!i*3,28) = vec_est!w.c(2,9)
vec!w_coeff1(!i*3,1) = vec_est!w.a(1,1)
vec!w_coeff1(!i*3,15) = vec_est!w.a(2,1)
vec!w_coeff1((!i*3)+1,2) = vec_est!w.@coefse(2,1)
vec!w_coeff1((!i*3)+1,3) = vec_est!w.@coefse(3,1)
vec!w_coeff1((!i*3)+1,6) = vec_est!w.@coefse(4,1)
vec!w_coeff1((!i*3)+1,7) = vec_est!w.@coefse(5,1)
''exogs
vec!w_coeff1((!i*3)+1,10) = vec_est!w.@coefse(6,1)
vec!w_coeff1((!i*3)+1,11) = vec_est!w.@coefse(7,1)
vec!w_coeff1((!i*3)+1,12) = vec_est!w.@coefse(8,1)
vec!w_coeff1((!i*3)+1,13) = vec_est!w.@coefse(9,1)
vec!w_coeff1((!i*3)+1,14) = vec_est!w.@coefse(10,1)
vec!w_coeff1((!i*3)+1,16) = vec_est!w.@coefse(2,2)
vec!w_coeff1((!i*3)+1,17) = vec_est!w.@coefse(3,2)
vec!w_coeff1((!i*3)+1,20) = vec_est!w.@coefse(4,2)
vec!w_coeff1((!i*3)+1,21) = vec_est!w.@coefse(5,2)
''exogs
vec!w_coeff1((!i*3)+1,24) = vec_est!w.@coefse(6,2)
vec!w_coeff1((!i*3)+1,25) = vec_est!w.@coefse(7,2)
vec!w_coeff1((!i*3)+1,26) = vec_est!w.@coefse(8,2)
vec!w_coeff1((!i*3)+1,27) = vec_est!w.@coefse(9,2)
vec!w_coeff1((!i*3)+1,28) = vec_est!w.@coefse(10,2)
vec!w_coeff1((!i*3)+1,1) = vec_est!w.@coefse(1,1)
vec!w_coeff1((!i*3)+1,15) = vec_est!w.@coefse(1,2)
endif
Re: Problem Saving Estimated VAR Coefficients
Posted: Fri Mar 16, 2012 9:05 am
Doesn't appear to be anything wrong with the code you posted. I just ran a test version of it and it worked fine. I'd say there is something else, elsewhere, going wrong.
create u 100 series s3=nrnd series s9=nrnd series s15=nrnd series s16=nrnd series s17=nrnd series s18=nrnd series s19=nrnd !w = 9 var var_est!w.ls 1 2 s3 s!w @ s15 s16 s17 s18 s19 !i=2 matrix(6,13) var9_coeff1 var!w_coeff1(!i*3,1) = var_est!w.c(1,1) var!w_coeff1(!i*3,2) = var_est!w.c(1,2) var!w_coeff1(!i*3,5) = var_est!w.c(1,3) '''not working - saving the same coeff as line above for some reason instead of coeff 3 (1st lag of second endog.) var!w_coeff1(!i*3,6) = var_est!w.c(1,4) ''exogs var!w_coeff1(!i*3,9) = var_est!w.c(1,5) '''these 5 lines save coeff 3-7 from eq1 but I want coeff 5-9 saved in these spots var!w_coeff1(!i*3,10) = var_est!w.c(1,6) var!w_coeff1(!i*3,11) = var_est!w.c(1,7) var!w_coeff1(!i*3,12) = var_est!w.c(1,8) var!w_coeff1(!i*3,13) = var_est!w.c(1,9)
Posted: Fri Mar 16, 2012 9:10 am
by mike_d
Would you be willing to look at the entire program? Could I send it to you as a text file? If not, no problem I will continue looking for the problem and I appreciate you checking that small snippet of code.
Mike
Posted: Fri Mar 16, 2012 9:30 am
Probably faster for you to run through it yourself first.
