serial correlation
Posted: Sun Mar 11, 2012 7:06 pm
hi there i really need help for my regression. I have found serial correlation via the BG LM test in my regression and want to fix it, but I am just unsure about the process. Do I just ad AR(1) to my regressors- and this is it? That fixes all the serial correlation problems or? I am a bit confused, please help me out, I'm a bit new to this.
NOTE when i entered AR(1) in my DW statistic was above the dU limit, so the test is conclusive right and there is no more serial correlation?
Here are my results:
Dependent Variable: FORRATE
Method: Least Squares
Date: 03/11/12 Time: 19:05
Sample (adjusted): 2 3142
Included observations: 3129 after adjustments
Convergence achieved after 7 iterations
C 0.072224 0.013922 5.187769 0.0000
ASIAN 0.116053 0.015257 7.606478 0.0000
BLACK 0.027659 0.004039 6.848391 0.0000
HISP 0.030511 0.002733 11.16292 0.0000
WHITE 0.012150 0.003812 3.187408 0.0014
MIDWEST 0.006834 0.000932 7.329219 0.0000
PACIFIC -0.028791 0.004338 -6.637492 0.0000
WEST -0.004759 0.001318 -3.610978 0.0003
BACH -0.084305 0.005275 -15.98341 0.0000
HS 0.018763 0.006859 2.735330 0.0063
POVERTY 0.026004 0.007442 3.494140 0.0005
UNEMP 0.393981 0.017074 23.07528 0.0000
LNMEDVALHUNIT -0.005808 0.000969 -5.995244 0.0000
AR(1) 0.364028 0.016902 21.53787 0.0000
R-squared 0.562896 Mean dependent var 0.049220
Adjusted R-squared 0.561072 S.D. dependent var 0.020924
S.E. of regression 0.013863 Akaike info criterion -5.714750
Sum squared resid 0.598633 Schwarz criterion -5.687687
Log likelihood 8954.726 Hannan-Quinn criter. -5.705036
F-statistic 308.5729 Durbin-Watson stat 2.212066
Prob(F-statistic) 0.000000
Inverted AR Roots .36
