Command to set Axis to Foreground
Posted: Sat Mar 10, 2012 4:44 am
by ethani
Does anyone know the command to set the data axis labelfor a (band) graph to the foreground? I know how to do this through the "options" menu in the graph object, but not how to program this directly.
Re: Command to set Axis to Foreground
Posted: Mon Mar 12, 2012 9:32 am
by EViews Glenn
Can you elaborate. I don't understand what you are trying to do.
Posted: Tue Mar 13, 2012 5:08 am
by ethani
I am looking for the programming command that is equivalent to the following menu option that can be accessed on a GRAPH object. Options>Axes & Scaling>Data axis labels>Axis ticks & lines: select "zero line foreground" in the lower of the two option menus.
In words, I want the X-axis of the graph to not be covered by a band graph.
Thanks,
Ethan
Posted: Tue Mar 13, 2012 10:13 am
by EViews Glenn
Try the axis command. I believe zerotop is the option that you want.
graph_name.axis(left) zerotop
