Page 1 of 2
How to generate equeation from the coefficients?
Posted: Sat Feb 18, 2012 8:22 am
by newuser_01
I don't know much about ARMA but hoping that one of you can help me understand this. I calculate the coefficients from timeseries but how can I can calculate the equation from the timeseries?
I've the
1. coefficients, std. error, t-statistics, prob. of
c (constant)
AR(1), AR(2), AR(3), AR(4), AR(5)
MA(1), MA(2), MA(3), MA(4)
and
2. R-squared, Adjusted R-squared, S.E. of regression, Sum squared, log likelihood, Mean dependent var, S.D. dependent var, Akaike info criterion, Schwarz criterion, Durbin-Watson stat
and
3. Inverted AR-roots, Inverted MA-roots
How can I calculate the equeation from here.. Based on these values if I write an equation then I'll be able to estimate the tomorrow's value. This is probably a dummy question for most of you..
Re: How to generate equeation from the coefficients?
Posted: Sat Feb 18, 2012 9:19 am
I don't understand your question.
Posted: Sat Feb 18, 2012 9:52 am
by newuser_01
I've a time series.
And calculated all these coefficients using the tool. But I don't have the equation.
If this was a linear equation then it might look like:
y = 2x + 3
So now I want to write the same for this non linear equation.
y = m*(y-1) + r*(y-2) + c etc... so I'm after something like this.
Posted: Sat Feb 18, 2012 10:22 am
You mean you just want to know how to include ARMA terms in an equation? Just add AR(1) as a regressors or MA(1)
Posted: Sat Feb 18, 2012 11:18 am
Or if what you're trying to do is forecast tomorrow's value, push the forecast button in the equation window.
Posted: Sat Feb 18, 2012 11:22 am
by newuser_01
something like that, let me clarify my questions again, let's say i have the following time series
t value
1 55
2 54
3 53
4 52
5 51
6 50
7 49
t is time.. value is the value... If I calculated ARMA stuff from this series and ended up with the following info:
c (constant)
and
and
And now I would like to write and equation for time (8) because I know the data up to 7, and will write the equation and then based on that I want to be able to calculate the value at 8. While doing that I will probably you the value at 7, 6, 5, 4, etc..
so if my value is y(t) the equation will look like
y(t) = q*(y(t-1) + y(t-2) + y(t-3)) + c etc.. it can be different than this but I don't know how to write this equation using the coefficients I have, can you give me an example.
You might say
y(t) = AR1 * y(t-1) + AR2 * y(t-2) - MA1 * y(t-1) ....
Hope it is clear now..
Posted: Sat Feb 18, 2012 11:23 am
by newuser_01
yes i would like to forecast tomorrow's value but I am not interested in the value, I would like to have the equation.
Posted: Sat Feb 18, 2012 12:20 pm
If y_t is the variable and we call e_t the error term, the equation is something like
y_t = ar(1)*y_(t-1) + ar(2)*y_(t-2) + e_t +ma(1)*e_(t-1)
Posted: Sat Feb 18, 2012 12:47 pm
by newuser_01
Thanks for the response, I understood all excep the error term, which one is the error term?
I guess with the constant (i.e. c) my equation will look like:
y_t = c + ar(1)*y_(t-1) + ar(2)*y_(t-2) + e_t +ma(1)*e_(t-1)
I've the following info but I don't know which one is the error term, and I don't have individual error term for each item:
c (constant)
and
and
Posted: Sat Feb 18, 2012 12:55 pm
e_t is the error term.
You might want to do some background reading on regression models in general and ARMA models specifically. Understanding how error terms fit in is central to anything you want to do with these equations.
Posted: Sat Feb 18, 2012 1:09 pm
by newuser_01
Thanks for the response, can you recommend something to read one error terms? I think it is called white noise.. and can you let me know whether I can calculate the error terms from the data I have?
Posted: Sat Feb 18, 2012 2:13 pm
Look at the Regression Analysis article on Wikipedia, particularly the section Linear Regression
Posted: Sat Feb 18, 2012 4:28 pm
by newuser_01
ok thanks, i will have a look, what about my second question:
Can error term (e(t), e(t-1)) be calculated from the data I have:
I have the time-series and the estimations and
c (constant)
and
and
Can error term (white noise) be calculated from these?
Posted: Fri Feb 24, 2012 12:14 pm
by newuser_01
Please see my question below, does anyone know how to calculate the error term (i.e. white noise) from the listed data I have?
c (constant)
and
and
Posted: Fri Feb 24, 2012 1:15 pm
Look up "RESID" or "residuals" in the help system.
