Error in FIML estimation
ming-ming
Postby ming-ming » Thu Feb 16, 2012 10:10 pm
I am trying to do a system estimation using FIML. However, the code I wrote didn't work. I have checked the possible error while entering the equations but found none. I specified thousands of initial values through loops but none of them worked either (I specified a very large number for the errors allowed before halting in the run dialogue window). I have attached the code as well as the data set I used. Could anybody help me out? Many Thanks!
cd C:\Users\Desktop\research\unnormalized wfopen(type=excel) "raw_data.xls" pagestruct(freq=a,start=1952,end=1998) output(t,o) MLE_case_1 poff mode quiet genr time = @trend+1 genr lshare = log(lincome/pgdp) genr kshare = log(kincome/pgdp) genr ly =log(rpgdp) genr ll = log(linput) genr lk = log(kpreal) genr lh = log(H) genr lyl = ly-ll system sys_mle sys_mle.append ly = -1/c(7)*log(c(1)*(exp(c(2)/c(3)*(time^c(3)-1))*(linput-1/c(4)*(h-linput)^((c(5)-1)/c(5))*(linput(1)-linput*(1-c(6)))^(1/c(5))))^(-c(7))+c(8)*(exp(c(9)/c(10)*(time^c(10)-1))*kpreal)^(-c(7))) sys_mle.append kshare = log(c(8))+c(7)*(ly-lk-c(9)/c(10)*(time^c(10)-1)) sys_mle.append log(1+r(1)) = -log(c(1)*(rpgdp/(exp(c(2)/c(3)*(time^c(3)-1)))/(linput-1/c(4)*(h-linput)^((c(5)-1)/c(5))*(linput(1)-linput*(1-c(6)))^(1/c(5))))^(1+c(7))*exp(c(2)/c(3)*(time^c(3)-1))/(c(4)*(h-linput)^((1-c(5))/c(5))*(linput(1)-linput*(1-c(6)))^((c(5)-1)/c(5))))+log(c(1)*(rpgdp(1)/(exp(c(2)/c(3)*(time(1)^c(3)-1)))/(linput(1)-1/c(4)*(h(1)-linput(1))^((c(5)-1)/c(5))*(linput(2)-linput(1)*(1-c(6)))^(1/c(5))))^(1+c(7))*exp(c(2)/c(3)*(time(1)^c(3)-1))-w(1)/pgdpdef(1)+(1-c(6))*(c(1)*(rpgdp(1)/(exp(c(2)/c(3)*(time(1)^c(3)-1)))/(linput(1)-1/c(4)*(h(1)-linput(1))^((c(5)-1)/c(5))*(linput(2)-linput(1)*(1-c(6)))^(1/c(5))))^(1+c(7))*exp(c(2)/c(3)*(time(1)^c(3)-1))/(c(4)*(h(1)-linput(1))^((1-c(5))/c(5))*(linput(2)-linput(1)*(1-c(6)))^((c(5)-1)/c(5))))) scalar ind = 0 scalar m = 5 !n2 = m !n3 = m !n4 = m !n5 = m !n6 = m !n7 = m !n9 = m !n10 = m scalar n = !n2*!n3*!n4*!n5*!n6*!n7*!n9*!n10 vector(n) logl for !i2 = 1 to !n2 for !i3 = 1 to !n3 for !i4 = 1 to !n4 for !i5 = 1 to !n5 for !i6 = 1 to !n6 for !i7 = 1 to !n7 for !i9 = 1 to !n9 for !i10 = 1 to !n10 scalar ind = ind+1 c(1) = 0.3 c(2) = 0.01+(!i2-1)*0.03 c(3) = -0.1+(!i3-1)*0.5 c(4) = 0.1+(!i4-1)*1.5 c(5) = 0.1+(!i5-1)*0.15 c(6) = 0.1+(!i6-1)*0.1 c(7) = 0.25+(!i7-1)*0.1 c(8) = 0.8 c(9) = 0.01+(!i9-1)*0.03 c(10) = -0.1+(!i10-1)*0.5 do sys_mle.fiml(m=100000,c=0.00001) logl(ind) = sys_mle.@logl next next next next next next next next scalar max_logl = @max(logl) wfsave mle_case_1
raw_data.xls
(28 KiB) Downloaded 274 times
Re: Error in FIML estimation
Postby EViews Gareth » Thu Feb 16, 2012 10:41 pm
I haven't looked in great detail, but at some point you have:
(H-LINPUT)^((C(5)-1)/C(5))
C(5) starts at 0.1, and you raise it by 0.15 each time through your loops. Your loops go up to 5. Thus C(5) is always less than 1, which means that C(5)-1 is negative, and then you raise it to a power that is less than 1. You can't raise a negative number to a power less than 1.
There may be other errors, but that's one that jumped out at me.
ming-ming
Postby ming-ming » Thu Feb 16, 2012 11:36 pm
Hi Gareth,
Thank you for your response. I checked the code again. Take the following one as an example
The base (H-LINPUT) is always positive and the power ((C(5)-1)/C(5)), as you mentioned, is negative. But I did not "raise a negative number to a power less than 1". Could you clarify a little bit? Thanks.
trubador
Did you use forum search?
Postby trubador » Fri Feb 17, 2012 3:08 am
As usual, this is not a software issue. You should always carefully check the equations and specifications in such complex models. In the first equation, for instance, you have the following specification that leads to negative values:
linput - (1/c(4) * (h-linput)^((c(5)-1) / c(5))*(linput(1)-linput*(1-c(6)))^(1 / c(5)))
The values generated by the RHS of minus operator are higher than that of the LHS (i.e. the values in your linput variable)...
ming-ming
Postby ming-ming » Fri Feb 17, 2012 10:14 pm
Thank you for your response. That is indeed an issue.
After I fixed that issue by choosing another group of initial values, which guarantees all positive bases before raised to any power, a similar error message occurs, i.e., "no valid observation..." or "near singular matrix..." Any suggestion on this issue?
Many thanks!
trubador
Postby trubador » Mon Feb 20, 2012 12:45 am
It is hard to tell without seeing the final version of your specification along with the workfile. However, it still seems to be an initialization problem. The specification of the model makes it difficult to find a feasible set of starting values for the parameters. It would be helpful, if you could gather some information on the parameter domain from similar studies...
