LR covariance in COINTREG versus LRCOV
Posted: Sat Feb 04, 2012 9:56 am
by ClintonGreene
The equation command COINTREG outputs the two-sided and one-sided long run covariance data members @lrcov and @lambda12cov To be sure I understand what this equation command is doing, I am trying to reproduce these data members using my own calculations of the cointegrating ols and x-var residuals, and then applying the group procedure LRCOV. My results consistently differ. Perhaps I am not using equivalent options in the LRCOV procedure, or perhaps I am making an error in expecting equivalence of the two approaches. Attached is a program which generates simulated data, then compares the two approaches to calculating the long run covariances. I would appreciate comment on whether the two approaches should be equivalent and if so, what modification is needed to get equal results.
Re: LR covariance in COINTREG versus LRCOV
Posted: Mon Feb 06, 2012 1:40 pm
Couple of things...
1. To answer your question as posed in the code. Yes, you want the first-stage regression to be over the whole sample (as you currently do).
2. The cointegrating regressors specification that you are estimating by hand differs from what you specified for EViews to compute. You are estimating a model in which there is a constant in the difference equations (which is the same as having a trend in the regressors specification). Your cointreg model doesn't have a regressor trend. You can change your code to match the cointreg specification modifying your commands to use
genr u_yh = cx1 genr y_r = cx2
3. Your LRCOV computations need to have a NOC option to not use a constant term.
gu.lrcov(window=sym,noc,lag=1,kern=bart,bw=fixednw,noc,out=omega) 'estimate long-run covariance, results placed in omega gu.lrcov(window=lower,noc,lag=1,kern=bart,bw=fixednw,noc,out=lambda) 'estimate one-sided (lag) covariance, results placed in lambda.
The resulting differences between the hand and the EViews computed matrices are on the order of 1e-15.
Posted: Mon Feb 06, 2012 3:46 pm
by ClintonGreene
Thank you, very helpful.
Posted: Mon Feb 06, 2012 8:04 pm
by ClintonGreene
Tried making the suggested changes, still get a difference in the two-sided lrcov more on the order of 10^-3. If you get different results running the same program, then this is a mystery. I am using Eviews 7.2 under WinXP.
If you modified the program and found a difference of more on the order of 10^-15, could you please email it to me to be sure we are working with the same modifications? My own version modified as I think you suggested is attached, I must be missing something.
I am also attaching an example of working file results, in which the matrix object "dif_omega" displays the difference between the lrcov (omega) as calculated via the two commands (cointreg vs lrcov).
Thanks again
Posted: Tue Feb 07, 2012 10:25 am
You have to estimate your EViews COINTREG on the full sample since that's what your by-hand calculations are using.
smpl @all equation e_eviews.cointreg(method=fmols, trend=const, regdiff, regtrend=none, lag=1, kern=bart, bw=fixednw) y x1 x2
Posted: Tue Feb 07, 2012 2:44 pm
by ClintonGreene
OK, now my results are consistent.
Posted: Tue Feb 07, 2012 3:28 pm
Note that since you have regtrend=none, the regdiff option shouldn't matter. If you have a constant or a trend, then it will.
