Starting values in Univariate GARCH models
tompan
Postby tompan » Wed Jan 25, 2012 1:49 pm
Dear all
I have a question about the starting coefficient values of the iterative process in a univariate GARCH model.The manual does not provide sufficient information about this topic.
What does the OLS/TSLS value indication option mean?
What happens if i select another option such as 0.8* OLS/TSLS , 0.5* OLS/TSLS, 0.3* OLS/TSLS, or zero?
How this alternative selection of starting value would change my results?
Regards
tom
Re: Starting values in Univariate GARCH models
Postby EViews Gareth » Wed Jan 25, 2012 2:17 pm
I think it is somewhat self explanatory. Ordinary Least Squares is performed first of all to generate a set of coefficients. These are then used as starting values. If you select the 0.8*OLS option, then they are multiplied by 0.8 before using them as starting values.
tompan
Postby tompan » Thu Jan 26, 2012 3:20 am
I guess im fully covered
Thanks for the reply
Regards
