Hypothesis test
Posted: Thu Jan 19, 2012 10:24 am
by badger_2000
I'm new to using EViews and am after some with a Wald test.
I need to test a hypothesis that a coefficient equals zero, against an alternate that it is greater than zero.
I've tried doing this:
c(1)=0,c(1)>0
But it didn't work. I'd be very grateful for any advice on how to do this.
Thanks.
Re: Hypothesis test
Posted: Thu Jan 19, 2012 10:36 am
Re: Hypothesis test
Posted: Wed Jan 25, 2012 2:56 am
by badger_2000
Thanks. I'm still not sure if I understand correctly.
I've got the t-statistic that the variable = 0 (7.2385).
But how do I use this to test against the hypothesis that it is greater than 0?
Thanks again.
Re: Hypothesis test
Posted: Tue Jan 31, 2012 1:25 pm
by Josh
You need to compare the t-value to the significant value you are using, this is normally taken from a table, including degrees of freedom. 7 is very high value so you can reject the null hypothesis. Hope this helps
