n step rolling forecast using garch
Posted: Thu Dec 15, 2011 9:06 am
by Nau2306
I am using eviews 6. Is it possible to produce n-step rolling forecasts of the garch model in eviews? Is there a specific fucntion in eviews to carry it out?
Re: n step rolling forecast using garch
Posted: Thu Dec 15, 2011 9:10 am
There is nothing built in, no.
Posted: Thu Dec 15, 2011 9:16 am
by Nau2306
Hmm is there any program available to do it in eviews? I have been trying to work on the codes i found on the forum itself but to no avail!!
Posted: Thu Dec 15, 2011 10:16 am
by Nau2306
Please find attached the workfile and program i have been trying. It is giving me 2 error messages:
1. error in sample : attempt to set sample outside of workfile range
structure/resize (from \workfile\proc menu) can expand the workfile range in 'SMPL 9/05/2016 9/06/2016'
My comments or queries: I have been estimating the data from 01/01/2000 to 05/03/2008 which represents the window= 3046. How come it is giving result for 2016??
2. WINSE is an illegal or reseerved name in 'DO_EQ1.FIT WIN8F [WINSE WINVAR]'
My comments or queries: I have tried to change the standard errors and variance series name but i am still getting the same error message.
Hope someone can help me.
Posted: Thu Dec 15, 2011 10:40 am
1. The sample error is from the line:
It isn't particularly easy to follow your code, but I believe you have set %1pere to be the date associated with the value 1 + !i + !window. Since !i runs from 1 to !length-!window+1-!step, the final run of the iteration loop, will be:
%1pere = date associated with 1+!length-!window+1-!step + !window = 1+!length
Since !length is the size of the workfile, you've just set %!pere to be the date associated with the first value outside of the workfile. That won't work.
2. You don't need the square brackets:
Posted: Thu Dec 15, 2011 12:36 pm
by Nau2306
Well I have tried to produce 1 step ahead rolling forecast with the garch using as guide the code posted by eviews esther on may 25, 2011 where 4 period ahead forecast was generated for rolling regression. This is what was done to generate the 4 period ahead forecast.
' 4-period-ahead forecast
%4pers = @otod(@dtoo(%start)+!i+!window-1) 'start point
%4pere = @otod(@dtoo(%start)+!i+!window+2) 'end point: %4pere - %4pers +1 = 4
if {%end} < {%4pere} then 'check whether the forecast end point is greater than the workfile end point
return
endif
So i tried to adjust it to generate 1 period ahead forecast but dont know if its correct.
I am confused about one thing. With the eq1.fit function, am I forecasting the error or the variance??
Posted: Thu Dec 15, 2011 12:39 pm
The fit function, as it states in the documentation, lets you forecast the mean equation's dependent variable, the standard error of that variable, and the GARCH conditional variance.
Posted: Thu Dec 15, 2011 1:00 pm
by Nau2306
Ok thanks
Think I will have to work out the n-step ahead forecast and try to understand better how to generate it.
Thanks for your help
Posted: Sat Dec 17, 2011 6:51 am
by Nau2306
hi
I have tried a new code for the 1 step ahead garch (1,1) forecast but it is giving me the following error
error in sample: attempt to set sample outside of workfile range
Structure/Resize (from Workfile/Proc menu) can expand the workfile range in 'SMPL 12 12+3046-1
I know its got to do with the sample estimation but I cant see what's wrong. Could someone please look into the matter? i am attaching the program as well as the workfile.
Posted: Mon Dec 19, 2011 8:59 am
I just ran that program on the workfile, and it didn't error.
Posted: Mon Dec 19, 2011 9:23 am
by Nau2306
Oh did u run it on eviews6?
Posted: Mon Dec 19, 2011 9:35 am
Yep.
