Johansen approach for testing cointegration
Posted: Mon Dec 12, 2011 4:38 pm
Hi everyone,
I'm measuring the effect of crime on investments in Rio de Janeiro. To do so, I'm using the following investment function:
I = f(Y, K, r, E, O) ; where I = investments, Y = GDP, K = capital stock, r = interest rate, E = investor's confidence, O = openess of the economy (X+M).
In order to measure the effect of crime, I added the "c" variable (= homicide rate) into the function, yielding to: I = f(Y, K, r, E, O,c).
Technically, I proceeded like that:
1) I tested the stationarity level of each varaibel and found that they are all integrated of order 1, thus I(1).
2) I tested the lag lenght optimality (of the unrestricted VAR model using all variables as endogenous) by the following command:
var var_ndi.ls 1 12 ndi rgdp ks lrir inv_conf openess
var_ndi.laglen(12, vname)
... and conclude for 1 lag (as optimal number of lag (following the SBC and the AIC).
3) I tried to select the optimal model (with/without trend, with/without intercept) by applying the Pantula's principle...
4) Then, I will run the cointegration test with this code :
coint.(s,1) lndi lrgdp lks lrir linv_conf lopeness hom
... determining the cointegration time series
5) correcting cointegration by a VECM.
MY QUESTIONS:
1) How to apply the Pantula's Principle. I mean, what is the code for programing?!?
2) How to insert (by coding) the VECM in my initial regression code?!?
Thank you in advance guys!
D.
MY QUESTIONS:
D.
