commands Error
Scalper
commands Error
Postby Scalper » Wed Dec 07, 2011 7:43 am
I am estimating a TVEC model and when i start to programming occurs errors. The beginning of routine is :
%dowjones="DJ"
%brentoil="BO"
%equation_cointeg="%dowjones c %brentoil"
smpl @all
scalar obstot=@obssmpl
scalar pi=@round(0.05*obstot)
%d="1"
!lag_0=1
!lag_k=8
%equation_dowjones="ddj ddj1 ddj2 ddj3 ddj4 ddj5 ddj6 ddj7 ddj8 dbo1 dbo2 dbo3 dbo4 dbo5 dbo6 dbo7 dbo8 c z"
%equation_brentoil="ddj ddj1 ddj2 ddj3 ddj4 ddj5 ddj6 ddj7 ddj8 dbo1 dbo2 dbo3 dbo4 dbo5 dbo6 dbo7 dbo8 c z"
'X X X X X XXXX first step X X X X X X X X X
series d{%dowjones}=d(%brentoil)
series d{%brentoil}=d(%dowjones)
after these commands when i run it shows up the following error message :" Can not assign string expression to numeric variable"
i don know why...Can you help me?
Best Regards
Scalper
Re: commands Error
Postby EViews Gareth » Wed Dec 07, 2011 8:46 am
You probably need:
series d({%dowjones})=d({%brentoil})
Scalper
Re: commands Error
Postby Scalper » Wed Dec 07, 2011 9:03 am
sorry,
i wanted to say :
series d{%brentoil}=d(%brentoil)
even so, it keep showing up
Re: commands Error
Postby EViews Gareth » Wed Dec 07, 2011 9:13 am
For the same reason - you need braces around your string variables.
Scalper
Re: commands Error
Postby Scalper » Wed Dec 07, 2011 9:47 am
i added :
for !defasagens=1 to !lag_k
series d{%dowjones}{!defasagens}=d{%dowjones}(-{!defasagens})
series d{%brentoil}{!defasagens}=d{%brentoil}(-{!defasagens})
and now :"DDJ is not defined :? "
i need braces as well?
Re: commands Error
Postby EViews Gareth » Wed Dec 07, 2011 9:54 am
Now you're missing parenthesis.
The D function requires parenthesis around the thing you're taking the difference of.
Scalper
Re: commands Error
Postby Scalper » Wed Dec 07, 2011 10:00 am
tahnk you very much Gareth.
However, always i write a command always show me up a message :(
Now, i wrote :
equation cointeg.ls(h) %equation_cointeg
and said " Alpha series in specification - %dowjones c %brentoil - @EXPAND can convert to catagorical dummies"
i have to create dummies??!!
Re: commands Error
Postby EViews Gareth » Wed Dec 07, 2011 10:14 am
Again, you need braces around your string variable.
Scalper
Re: commands Error
Postby Scalper » Wed Dec 07, 2011 10:32 am
Can you specify where?
Re: commands Error
Postby EViews Gareth » Wed Dec 07, 2011 10:38 am
You only have one string variable in that line...
equation cointeg.ls(h) {%equation_cointeg}
Scalper
Re: commands Error
Postby Scalper » Wed Dec 07, 2011 10:45 am
i really did that but keep showing me up :
" Alpha series in specification -DJ- @EXPAND can convert to catagorical dummies"
The routine that i have is :
Estimation a Threshold VEC with 2 Regimes
%dowjones="DJ"
%brentoil="BO"
smpl @all
%d="1"
!lag_0=1
!lag_k=8
%equation_brentoil="dbo ddj1 ddj2 ddj3 ddj4 ddj5 ddj6 ddj7 ddj8 dbo1 dbo2 dbo3 dbo4 dbo5 dbo6 dbo7 dbo8 c z"
series d({%dowjones})=d({%dowjones})
series d({%brentoil})=d({%brentoil})
series d({%dowjones}{!defasagens})=d({%dowjones}(-{!defasagens}))
series d({%brentoil}{!defasagens})=d({%brentoil}(-{!defasagens}))
cointeg.makeresids residcointeg
series z=residcointeg(-{%d})
sort z
'X X X X X XXXX STEP 2 X X X X X X X X X
for !meses=pi to (obstot-pi)
series vec1res1empil_{!meses}
series vec1res2empil_{!meses}
mpl 1 1+!meses-1
equation vec1A{%dowjones}_{!meses}.ls(h) %equation_dowjones
vec1A{%dowjones}_{!meses}.makeresids res1_vec1A_{!meses}
equation vec1A{%brentoill}_{!meses}.ls(h) %equation_brentoil
vec1A{%brentoill}_{!meses}.makeresids res2_vec1A_{!brentoil
smpl 1+!meses-1+1 1+obstot-1
equation vec1B{%dowjones}_{!meses}.ls(h) %equation_dowjones
vec1B{%dowjones}_{!meses}.makeresids res1_vec1B_{!meses} }
equation vec1B{%brentoil}_{!meses}.ls(h) %equation_brentoil
vec1B{%brentoil}_{!meses}.makeresids res2_vec1B_{!meses}
for !empilvec1A= 1 to !meses
vec1res1empil_{!meses}(!empilvec1A)=@elem(res1_vec1A_{!meses}, @otod(!empilvec1A))
vec1res2empil_{!meses}(!empilvec1A)=@elem(res2_vec1A_{!meses}, @otod(!empilvec1A))
for !empilvec1B=!meses+1 to obstot
vec1res1empil_{!meses}(!empilvec1B)=@elem(res1_vec1B_{!meses}, @otod(!empilvec1B))
vec1res2empil_{!meses}(!empilvec1B)=@elem(res2_vec1B_{!meses}, @otod(!empilvec1B))
smpl @all
group resvec1_{!meses} vec1res1empil_{!meses} vec1res2empil_{!meses}
matrix varcovvec1_{!meses}=@cov(resvec1_{!meses})
for !meses=pi to obstot-pi
table(obstot+1, 2) grid1
grid1(1, 1) = "threshold"
grid1(1, 2) = "traçovarcov"
grid1(!meses, 1)=@elem(z, @otod(!meses))
grid1(!meses, 2)=@trace(varcovvec1_{!meses})
matrix(obstot-pi-pi+1, 2) result1
result1(!meses-pi+1, 1)=@elem(z, @otod(!meses))
result1(!meses-pi+1, 2)=@trace(varcovvec1_{!meses})
!mintraco1=@min(@columnextract(result1, 2))
scalar mintraco1=!mintraco1
if result1(!meses-pi+1, 2)=!mintraco1 then rowvector solucao1=@rowextract(result1, !meses-pi+1) endif
!gama1=solucao1(1)
scalar gama1=!gama1
sample s1 if z <= !gama1
sample s2 if z > !gama1
smpl s1
scalar obs1=@obssmpl
equation regime1{%dowjones}.ls(h) %equation_dowjones
equation regime1{%brentoil}.ls(h) %equation_brentoil
regime1{%dowjones}.makeresids resid1_regime1
regime1{%brentoil}.makeresids resid2_regime1
smpl s2
scalar obs2=@obssmpl
equation regime2{%dowjones}.ls(h) %equation_dowjones
equation regime2{%brentoil}.ls(h) %equation_brentoil
regime2{%dowjones}.makeresids resid1_regime2
regime2{%brentoil}.makeresids resid2_regime2
'XXXXXXXX STEP 3 XXXXXXXXX
'REGIME1
smpl s1
stom(resid1_regime1, vetor_resid1_regime1)
stom(resid2_regime1, vetor_resid2_regime1)
scalar obsv1=@rows(vetor_resid1_regime1)
'REGIME2
smpl s2
stom(resid1_regime2, vetor_resid1_regime2)
stom(resid2_regime2, vetor_resid2_regime2)
scalar obsv2=@rows(vetor_resid1_regime2)
smpl @all
smpl s1
'REGIME 1
for !empilregime1=1 to obsv1
residuos_tvec2(!empilregime1, 1)=vetor_resid1_regime1(@otod(!empilregime1))
residuos_tvec2(!empilregime1, 2)=vetor_resid2_regime1(@otod(!empilregime1))
smpl s2
'REGIME 2
for !empilregime2=1 to obsv2
residuos_tvec2((!empilregime2+obsv1), 1)=vetor_resid1_regime2(@otod(!empilregime2))
residuos_tvec2((!empilregime2+obsv1), 2)=vetor_resid2_regime2(@otod(!empilregime2))
smpl @all
matrix sigma2=@cov(residuos_tvec2)
scalar tracosigma2_d{%d}=@trace(sigma2)
Re: commands Error
Postby EViews Gareth » Wed Dec 07, 2011 10:55 am
You're missing lots of braces around string variables.
Scalper
Re: commands Error
Postby Scalper » Wed Dec 07, 2011 11:03 am
why?
Re: commands Error
Postby EViews Gareth » Wed Dec 07, 2011 11:04 am
Scalper
Re: commands Error
Postby Scalper » Wed Dec 07, 2011 11:23 am
when i write : equation cointeg.ls(h) {%equation_cointeg}
as you wrote
the Eviews show me up " Alpha series in specification -DJ- @EXPAND can convert to catagorical dummies" and i dont know why
