ECM forecast
Posted: Wed Nov 30, 2011 7:34 am
by PMaier
I would appreciate some help forecasting an ECM model. The equation I'm trying to forecast is a traditional ECB equation:
f2 = beta(1)*f2(-1) - beta(2)*(f2_level(-1)-beta(3)*oil(-1) - beta(4)*comm_agriculture(-1)-beta(5)*comm_metals(-1)),
whereby f2 is the series in first differences and f2_level the series in levels. The attached workfile contains all series.
ecm model.wf1
(23.43 KiB) Downloaded 921 times
Here's the code to set up the basic framework:
coef(5) beta series f2_level = @cumsum(f2) ' Test the cointegration relationship -- first the LR relationship, then the SR relationship smpl 1980q1 2007q4 equation eq_lr.ls f2_level = c(1)*oil - c(2)*comm_agriculture-c(3)*comm_metals equation eq_ecm.ls(n) f2=beta(1)*f2(-1) -beta(2)*(f2_level(-1) -beta(3)*oil(-1) - beta(4)*comm_agriculture(-1)-beta(5)*comm_metals(-1)) fit f2_hat plot f2_level @cumsum(f2_hat) ' Forecasting ' Build a model model model_test model_test.merge eq_lr model_test.merge eq_ecm
In other words, I'm first generating f2_levels, then test the cointegration relationship, then estimate the ECM (don't look too hard on the econometrics; I'm just using this data as illustration).
Then, however, I run into difficulties as I'm trying to cast this in model form. I think I need to make explicit to the model that f2=d(f2_level), but if I try adding this equation, I get the error message that "f2 is specified as endogenous in another equation" (not surprising). So I'm a bit at a loss how to accomplish this.
Any advice would be greatly appreciated!
Many thanks, Philipp
Re: ECM forecast
Posted: Wed Nov 30, 2011 11:55 am
by PMaier
I probably overlooked the simple solution. I think the following should be correct:
coef(5) beta series f2_level = @cumsum(f2) ' Test the cointegration relationship -- first the LR relationship, then the SR relationship smpl 1980q1 2007q4 equation eq_lr.ls f2_level = c(1)*oil - c(2)*comm_agriculture-c(3)*comm_metals equation eq_ecm.ls(n) f2=beta(1)*f2(-1) -beta(2)*(f2_level(-1) -beta(3)*oil(-1) - beta(4)*comm_agriculture(-1)-beta(5)*comm_metals(-1)) ' Forecasting model model_test model_test.merge eq_ecm model_test.append f2_level = f2_level(-1)+f2
... and then solve the model dynamically.
I'm posting this in case anyone else struggles with the same issue -- or, if I'm wrong, to be corrected! :-)
Thanks, Philipp
