Forecasting variance/covariance Diagonal BEKK
Posted: Wed Nov 23, 2011 3:17 am
Hello, for my thesis I am trying to forecast the variance and covariance of two series (spot and futures series), both in- and out-sample (in-sample 85%). The code below was found on this forum, however when I try to run the forecast something goes wrong and the forecast is not produced. I believe there might be a mistake in the section where the dynamic series are formulated, however due to lack of eviews knowledge I am not sure. I hope someone is willing to help. In the attachements I added all the data, the workfile and the code I use.
Kind Regards, Erik Homan
'First order model (BEKK-GARCH(1,1)) is assumed.
sym(2) M
vector(2) A1
vector(2) B1
'Create a system
%sys = "sysbekk"
system {%sys}
'{%sys}.append duks = c(1)
'{%sys}.append dukf = c(2)
{%sys}.append logspot = c(1)
{%sys}.append logfirst= c(2)
'Estimate the system as diagonal BEKK
'smpl @first @first+368
smpl @first @first+2440
{%sys}.arch @diagbekk c arch(1) garch(1)
'Save the conditional series
{%sys}.makegarch
'Compute the in-sample hedge ratio
'series hr = garch_02/garch_01_02
series hr = garch_01_02 / garch_02
delete garch*
'Rolling forecasts
'for !i=1 to 154
for !i=1 to 10
'smpl @first @first+368+!i-1
smpl @first @first+2440+!i-1
{%sys}.makegarch
{%sys}.makeresids
'Generate new series for forecasted variables
for %y GARCH_01 GARCH_02 GARCH_01_02 RESID01 RESID02
series {%y}f= {%y}
'Organize the estimated coefficients into matrix form.
'Constant is assumed to be the only exogenous variable in each mean equation.
'Therefore coefficients of variance specification should start at c(3).
M(1,1)={%sys}.@coefs(3)
M(1,2)={%sys}.@coefs(4)
M(2,2)={%sys}.@coefs(5)
A1(1)={%sys}.@coefs(6)
A1(2)={%sys}.@coefs(7)
B1(1)={%sys}.@coefs(8)
B1(2)={%sys}.@coefs(9)
'Number of observations used in the estimation
!n={%sys}.@regobs
'Define out of sample forecast horizon
!h = 1
'Perform dynamic forecasts via adjusting the sample (do not forget the missing value due to lag structure)
for !j=1 to !h
smpl @first+!n+!j @first+!n+!j+1
GARCH_01f = M(1,1) + A1(1)^2*RESID01f(-1)^2 + B1(1)^2*GARCH_01f(-1)
GARCH_02f = M(2,2) + A1(2)^2*RESID02f(-1)^2 + B1(2)^2*GARCH_02f(-1)
GARCH_01_02f= M(1,2) + A1(1)*A1(2)*RESID01f(-1)*RESID02f(-1) + B1(1)*B1(2)*GARCH_01_02f(-1)
RESID01f = 0
RESID02f = 0
'Out-sample hedge ratios
series hrf = garch_01_02f / garch_02f
'Combine in-sample and out-sample hedge ratios into one series
hr = hrf
delete garch* resid0*
smpl @all
